Question about Blue Plasmacar
Show how to attach steering wheel to plasma car
My89 dodge dakotas steering is copletely loose and wheels dont turn at all everything seems to be attached,whats the problem
where to start? any steering fluid? steering belt ok? steering wheel tight? steering pump ok? front end pitman and idler arm(s) ok? front end bushings or rod ends ok? steering box gears steipped? steering rack could be stripped. check all these first then get back to me.
Jun 05, 2016 | Dodge Cars & Trucks
My steering wheel has some play in it
with key on engine off if you can move wheel more than two inches each way with two fingers pressing on wheel you've got a steering problem, it will take a look at your steering box or rack/pinion and your ball joints (where it attaches to wheels ) to see exact cause
May 14, 2016 | Cars & Trucks
My steering wheel wiggles
You could have an out-of-balance or out-of-round condition on the front tires, but similarly it could be something more serious
-loose front wheel hub
-worn front suspension joint
-worn steering tie rod joint
-loose steering box mounts
-loose steering column u-joint
-loose or word steering wheel attachment
Oct 31, 2013 | 1991 GMC Sonoma
Why is the steering wheel not straight as the car goes straight?
Because the car need a front-end alignment.
Here's how that works.
The steering wheel is attached to 2 tie rods (they go by different names sometimes).
These tie rods are then attached one to each front wheel.
There are at least 2, and sometimes 4 adjustments for these under the front of the car.
When someone does a front end "alignment". they will loosen all these joints and will set the wheel straight to match the direction of the car.
Over the years, these parts wear and the wheel gets crooked.
Be blessed.
Feb 18, 2013 | 2005 Lexus SC430
How to remove steering wheel, 2000 blazer
Parts stores sell an inexpensive steering wheel removal puller. Follow repair manual removal procedure, so the air bag doesn't activate. The steering wheel is retained by a large nut on the steering wheel shaft. Remove the nut, and attach the puller to wheel-it should pull right off.
May 16, 2012 | 2000 Chevrolet Blazer
How to drain (and replace) power steering fluid ?
take off the low pressure hose,( the ones that attach with hose clamps)then start the car turn the steering wheel back and forth, re-attach the hose and fill with new fluid, it might take a bit to get all the air out, just keep turning the wheel
Oct 28, 2010 | 2007 Chevrolet Malibu Maxx LTZ Hatchback
The controls on the steering wheel stopped working and the radio doesnt work either
Replace the clock spring under steering wheel, if applicable to your vehicle
May 06, 2010 | 1995 Buick Riviera
My wheels wont turn with the steering wheel
you have a steering linkage broken possibly the pitman arm. it attaches to the steering box
Dec 10, 2008 | 1999 Dodge Durango
Blue Plasmacar Logo
182 people viewed this question
Top Blue Toys Experts
thegtw
Tom Chichester
Are you a Blue Toy Expert? Answer questions, earn points and help others
