Question about Crown XTi 4000 Amplifier
Multiple crowns crown xti 2002 and 4000 both flicker after pushing the power button then stop after a few seconds.
  • 4234 Answers
SOURCE: i need the schematic for the crown amplifier
These are available for purchase from Crown. Generally they are not available on the web. Is there a specific problem that you are having?
Dan
Posted on Jun 29, 2009
Ganx
  • 113 Answers
SOURCE: Crown XTi 4000 brand new digital amp how can i
Hiya, to unlock press PREV and NEXT until it says unlocked.
The short 1 sounds a little serious though. Have you tried taking off the speakers?? If still there then suggest contacting crown. They have a pretty good no nonsense 3 year warranty
Best of luck
Posted on Jul 14, 2009
petraman7
  • 1175 Answers
SOURCE: dsp off
Try here:
http://www.crownaudio.com/express.htm
Posted on Apr 17, 2010
SOURCE: Crown Xti 2000, signal to both channels, no sound
common problem with xti series... all the amp needs is a soft ware update contact crown and they can sort it for you... you dont have to send the amp back to them. it was a verry common fault with all the early xti amps..
Posted on Sep 23, 2010
  • 140 Answers
SOURCE: Where are the fuse located
The fuses are on the inside
Posted on Dec 14, 2010
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
I need to know how to set a h005 haffstreuner watch after battery change
This is for the HA005:
B) SETTING THE TIME
1. Pull the crown out to the 2nd position.
2. Turn the crown to set hour and minute hands.
3. When the crown is pushed back to the normal position, small second hand begins to run.
C) SETTING THE DATE
1. Pull the crown out to the 1st position.
2. Turn the crown clockwise to set the date.
*If the date is set between the hours of around 9:00 PM and 1:00 AM, the date may not change on
the following day.
3. After the date has been set, push the crown back to the normal position.
E) CHRONOGRAPH RESET (INCL. AFTER REPLACING BATTERY)
This procedure shoud be performed when the chronograph second hand does not return to zero position
after the chronograph has been reset, and including after the battery has been replaced.
2. Press button "A" to set the chronograph second hand to the zero position. The chronograph hand can
be advanced rapidly by continuously pressing button "A".
3. Once the hand have been zeroed, return the crown to the normal position.
* Do not push crown to normal position while the chronograph second hand returns to zero position.It
stops on the way when crown are returned to normal position and its position is recognized as zero
position.
May 25, 2014 | Hitachi HA00593 Power Supply
My xti 6002 goes to thermal protect after few seconds after i switch it on .The problem is only on ch2 and ch1 is fine.what is causing the problem.
I've been seeing this a lot. The outputs are common failure. Needs to go to a shop. Shorted transistor is likely the cause.
Jan 11, 2014 | Crown XTi 6002 1200w Stereo Power...
My amp was blinking while it was working then it went off.Now it doesn't power up..Crown Xti 4000
Power supply likely failed. Electrolytics are the primary culprit.
It should have a switchmode power supply, so it is lmost likely the 5 volt section failed.
Sep 17, 2012 | Crown XTi 4000 Amplifier
My new nixon 42 20 when i reset the chrono the second hand doesnt go back to zero it goes to 16 seconds past how do i sort this problem its annoying !
  • Undo & pull the crown all the way out,then
  • undo the adjuster button (the one underneath the crown)
  • push the stop/start adjust button one push at a time and it will move in slight increments,keep going till you get the second hand on the 12 mark
  • then push the top adjuster and it will go back to the 12 mark.
  • Push the crown in and wind your adjusting buttons up and you have finished
Aug 20, 2010 | Nixon 4220 PU Chrono Watch Black
How do I cahge time on french tank
  1. click the top button to stop the second hand
  2. click the bottom button to reset the timer
  3. pull the crown out all the way
  4. twist the crown forward hard and fast for a few seconds. The minute hand will start advancing very quickly.
  5. when the desired date and time is reached, push the crown back in place. If you missed the time, pull the crown back out and twist backwards. The minute hand will move slowly in reverse. If you twist hard and fast, the minute hand will start spinning in reverse again.
Jan 16, 2010 | Cartier Tank Francaise W51001Q3 Wrist...
The second hand on my invicta chronograph watch doesn't reset to zero
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Dec 26, 2009 | Invicta Subaqua Noma Iii S
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
I need the schematic for the crown amplifier xti 1000 crown xti 1000 2-channel amplifier
Dan
Jun 28, 2009 | Crown XTi 2000 2-Channel Amplifier
Rolex ladies DayJust
No problem pulling it the way out its okey,Wind it the crown until calendar move so the hands move properly.When you going back the crown,push the crown hardly going inside while pushing, wind the crown until you reach the end so its locks properly,because has a thread needs to lock so it will not wind freely,that all Working guy, txt me whatever happen.
May 02, 2008 | Rolex Daytona 116520 Wrist Watch
Crown XTi 4000 Amplifier Logo
49 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
