Question about Home
I have a superflush 2002" there is no water coming through to flush the toilet no power there
5 Suggested Answers
brighthm
  • 36 Answers
SOURCE: not enough water in the toilet bowl
Adjust the floating stopper in the tank to allow more water to fill the tank
Posted on Oct 29, 2008
  • 3 Answers
WellI had the same problem with a client. never seen a stubborn problem like this. I was worried there was no vent on the toilet. My resolution was to get a new flapper from Moen. I replaced the existing flapper that had the yellow float. the float is designed to kepp the chain away from the flap. the existing flap had a vent hole in it. compare it to the new moen unit and you will see what im talking about. After the replacement things were better. Cheers
Posted on Jul 17, 2009
dmftrucker
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
SOURCE: My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Posted on Jan 24, 2010
Kohler flush problems
If it has a power flush (i.e hole about 1" in size opposite side of flushing direction) that hole gets plugged by minerals from the hard water, when it does the flush will be much weaker. To clean it, use a bent coat hanger and ream out the deposits as far in as you can reach. Then turn off the water supply, flush the toilet, then quickly pour one pail full of water into the toilet to drop the water level to minimum. Get "Lime Away" at H/Depot, pour in 1 cup and let sit overnight to eat the remaining hard water deposits from the bowl and power flush. In morning turn on water flush a few times, should wok good as new. Repeat anytime hole starts to get plugged.
Aug 21, 2014 | Home
Toilet flushes but does not have the power to flush down waist
Aug 14, 2014 | Home
Toilet wont flush
Jul 27, 2014 | Home
How do you adjust the clip so the water level increases?
You don't adjust the clip as it attaches to the pipe to automatic turn off the water at the right level, but your water may be set at to high a level that it overflows into the bowl. When that happens you can do 2 things to correct it: 1 at the wall where the cold water comes out to the toilet you can adjust it to slow the supply of water to a little less. 2. You can adjust the screw inside tank to tighten (turning screw one way) to adjust water level to shut off quicker or adjust tank screw the other way to fell take water up higher. Flush the toilet and observe the power of the flush. Allow the tank to fill until the water shuts off. Repeat the procedure to adjust the float and water level, if desired.
Apr 26, 2014 | Plumb Craft Waxman 7030700T Perfect Flush...
Jabsco electric toilet won't flush
Check the power source to toilet and all wiring conversed.
Sep 07, 2017 | Jabsco Home
Toilet does not flush clean. sometimes two or thtree flushes are needed to flush B.M> debris down. We have had the plumber out twice, once to install and the second time to raise the water level to...
Welcome to the world of 1.6 gallon flush toilets. You have already done everything that can be done to help the problem and no you are not the only people having this problem. This is just the beast!
They have had this problem with these 1.6 flush toilets from the get go and have come out with power flush toilets to fix this but hold on to your wallet. There are some toilets out there that work better without the power flush made buy American Standard and Kohler but they will run you more then the Jacuzzi.
Sorry I wish there was a better answer to this.
Mar 23, 2011 | Jacuzzi Home
Kohler 1.6 power flush dose not flush. It takes a few flushes to empty. Doesn't seem to have enough water coming in. And enough power.
The power it flushes with is relevant to the amount of water in the tank if the water in the tank is not up to the mark on the tank wall then adjust the water level float until it is. If this problem just started out of the blue then you need to look into an obstruction in the toilet water seal trap or possibly the drain.
Feb 18, 2011 | Kohler Home
My toilet does not flush properly. It seems to
You might check under the rim of the toilet, there are about 12 little holes that when you flush water comes out to start the most important part of the flush. The swrill, with out it hard to flush. Talk a piece of wire hanger ( I know "NO WIRE HANGERS") and use it to push up into the holes. Hard water deposits sometimes build up there.
Sep 27, 2009 | Home
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
Grinder wont turn and toilet not flushing
Disconnect the power and pull the pump out and examine the pump. Simple and easy!
May 23, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Home Logo
71 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
