Sharp lc 46e77unno power. ic bad tny264pn. change. still no power.
4 Suggested Answers
  • 1779 Answers
SOURCE: power supply bad on Sharp Aquos LC - bad board - schematic to ID?
Buy the green light going on means Standby is ok. Next, would be to locate the plug coming from the main board to the power supply and find the post that says PO which means power on. With your meter on that post, press the power button as see if the reading goes High, if it does then the main board is able to turn on the power supply. Next, find the plug on the power supply that goes to the inverter( the long board on the side) remove it and see if you have 24 volts coming out of the power supply when you press the power. If you do, then the inverter board is bad, if you don't have 24 v, then the power supply is bad. There are NO diagrams available for these set other than a flow chart if you can find one. A regular svc tech does'nt need a manual for these anyway.
Let me know how you do Kathy ?
Posted on May 17, 2009
  • 8457 Answers
SOURCE: sharp LC-26d4u tv won't turn on/power light is off
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
Posted on Aug 17, 2009
budmrtn
  • 11361 Answers
SOURCE: Sharp Aquos LC-C3242U power issues
Do you get any indicator lights at all, if you do, then the 5v standby circuit is working, if you get nothing at all, then the main power supply will be the first palce to look, blown fuse? capacitors?
Posted on Nov 06, 2009
Sound went out on tv, what has caused this?
hi plug some earphone in to the tv, if you can hear sound the sound prossesor is working, could be faulty amp ic capacitor or bad speaker, thanks
shaun
Feb 14, 2017 | Sharp Televison & Video
How do I fix my Sharp tv model LC-42D62U? On the tv screen now shows horizontal lines with repeating ghost images.
Hi Paul,
The horizontal lines on the screen are virtually NEVER caused by a bad T-con board. These horizontal lines indicate a defective LCD panel (screen). The Screen has small ICs that become defective overtime and that it isn't fixable unless replacing the entire screen.
Sep 13, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LC-42DH77E Sharp No picture Green led comes on then red LED comes on after a short while RED LED flashes twice then reoccurs .
maybe its on power supply try to check at power supply section check nearby parts of regulator ic if you can, test those passive and active parts using vom if those parts are ok then the regulator ic is defective
Apr 30, 2011 | Sharp LC40E77U LCD TV
Pin code for sharp aquos television model number Lc 32 gdbe
Phone Sharp customer care, they will guide you trough the process.
Nov 08, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp LC-26d4u tv won't turn on/power light is off
Aug 17, 2009 | Sharp LC-26D4U 26 in. LCD Television
Power light on but no audio no video
There must have been an internal problem. Some ic's have gone bad. Go for a check to determine wat is to be changed.
It is a minor thing.
Rate this.
Mar 22, 2009 | Sharp LC-26SH10U 26 in. LCD Television
Sharp lc-46d82u i can not turn on the tv ,the green light is on,
check ur power source,change batteries in ur remote.Do all that same prob.ur power board ic converter is dead must change.
Dec 22, 2008 | Sharp LC46D82U 46 in. LCD HDTV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
