Philips transmitter ad901wt - Televison & Video
What is a Philips rd modulator pm61138 used for .
RF modulator is the part of a transmitter that converts an audio and/or video (or a data stream) signal into a radio frequency signal.
An rf modulator is commonly found inside such things as a video recorder/player or dvd player to allow it to be connected to an analogue tv through the aerial connection and your rf modulator is a stand alone type designed to do exactly that.
May 11, 2018 | Philips Televison & Video
I have the philips mcm530 micro system and want to tune in a wireless speaker to the system so I can take the speaker outside. Is that possible?
The philips only receives bt audio it doesn't transmit them. You need a wireless system that includes a receiver and transmitter. The transmitter needs to be able to be connected to the speaker outputs of your philips system. Since I don't know what country you live in it is difficult to recommend anything as what is available in one area may not be available in another
Sep 01, 2016 | Philips Audio Players & Recorders
Does the shb4000 pair with more than one device
Not at the same time, but after you paired it with one transmitter, you could pair it with another. Make sure the first transmitter is switched off, because as long as it is connected to a transmitter, it won't accept another source.
Dec 27, 2014 | Philips SHB4000WT Bluetooth Stereo Headset
AD901WT/12 pinout connector
And which sockets in particular do you require the standard pin outs from?
Jan 24, 2011 | Philips Televison & Video
Philips LX3950W - no signal to rear speakers
check to se if your reciever channel number is set to the same as your transmitter channel number. press and hold down sound butten on remote to set transmitter number .set reciever number button on reciever unit. try setting both to number 4.
Dec 29, 2009 | Philips LX3950W System
Problems withthe digital switchover and retuning my freeview box!
There are a few problems turning up as a result of the update. Do a factory settings on the box if it has the option to do so. Be aware of the actual transmitter you are on and the channels/frequencies it uses so when tuning you know whether its finding channels at the bottom, middle or top of the band. Sometimes you may need to unplug the aerial upto or after a particular channel to stop the box tuning unwanted transmitters. If you are picking more than 1 transmitter up you will often get extra channels in wrong locations
Nov 06, 2009 | Philips Televison & Video
PHILIPS 21 rf service menu
To enter SDAM, press the following key sequence on the remote control
transmitter: 0 6 2 5 9 6 directly followed by the MENU button (do not allow
the display to time out between entries while keying the sequence).
Dec 30, 2008 | Philips 21PT4475 TV
Does Gogear charge via the USB plug or only via the 13 amp plug
You should be able to use the play side but I do not think you will be able to charge it.
The transmitter side is taken from the earphone socket.
The power comes from the mains plug via. the Philips lead and is at 5 volts.
I could be telling you wrong as I do not know what adaptor you are looking to purchase.
Dec 06, 2008 | Philips GoGear HDD6330 MP3 Player
I am trying to program a new remote and i need my remote code to program the tv can you find the code for magnavox msd513f
Not sure your MSD513F is not listed, and dont know your chassis # so here is what I can offer with what you gave me from the manuals
FOR THE
51MP392H/17
PHILIPS phone # 1-800-432-8542
Universal remote control - RC2018/1
Universal RC managing TV and peripherals
from the parts manual
Cabinet & Accessory Parts
REMOTE Transmitter, RC2061/01 . . . . . . . 3128 147 14611
Sep 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
Just bought a new Philips MP3 Player Model SA3025/37 and was wondering if I can use it in my car?
You can use any MP3 player in your car by connecting to an FM transmitter.
Look for FM transmitters on E-Bay.
They are powered by either battery, or cigarette lighter adaptor.
They plug into the headphone socket of the MP3 and convert the output into an FM signal, which you can tune your car radio into.
Jun 07, 2008 | Philips Audio Players & Recorders
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
