Question about Refrigerators
Model# 253 9280213 and serial # WBOi823164 Kenmore
This freezer gets really hot on both sides of it. Is this common on this model. I've placed it in the garage and it's been hot. Could this cause this problem.
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
jumptrout51
  • 3361 Answers
SOURCE: Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Posted on Feb 23, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Posted on Apr 22, 2009
SOURCE: Freezer won't work in garage in cold weather
Modern fridge/freezers are built to automatically defrost themselves. To do this they require that the room temperature is well above freezing to allow the defrost to take place. If you site the freezer in too cold an environment it is unable to defrost itself and will eventually stop working. It sounds strange but if it is too cold the freezer cannot work. The solution is to buy and fridge/freezer that does not automatically defrost itself if you want it to work in a cold environment.
Posted on Jun 12, 2009
heatman101
  • 43501 Answers
SOURCE: I have a GE Profile side-by-side Refrig (model
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 12, 2010
Kenmore Model 10654613300 Freezer over freezing
In the freezer side there is a panel in the back. behind the panel are the evaporators. over the evaporators are heaters you will find one of then broken from water dropping on it the bottom one was broken on mine. put a fan to the freezer and thaw it out. get the model and serial numbers and look on ebay.com. or there is a place called http://www.repairclinic.com/
These are not hard to change but above all UNPLUG THE FRIG OR THEY MAY PUT YOU IN ONE.
Hope this helps.
Sep 21, 2014 | Kenmore Elite Side By Side Refrigerator -...
GE side by side refrigerator model GSS22JEPD freezer ices up.
remove the freezer shelves and remove rear inside panel in freezer,under the evaporator located here theres a heating element,it has probably opened up and can no longer heat,this is a very common problem with g.e. SxS refrigerators,replace it by unplugging unit,then remove 2 screws holding heater bracket and unplug heater and replace g.e.heater part # is WR51X10101
Jun 16, 2012 | GE Refrigerators
Kenmore bottom refrigerator has er ff code
Looks like it lost a cooling agent.
Aug 29, 2017 | Kenmore Refrigerators
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
If refrigerator is still cooling, but not real cold, could it just use freeon or motor replaced? I paid almost $1,000 on it in 2005. My husband tells me refrigerators are generally made to last 10 years....
Ok
How is the freezer? Everything frozen solid?or is that warm too?\
If freezer seems good ,then you 're gonna be ok.Meaning your compressor is fine , and there is a refrigerant charge. In this case ,you probably have a defrost problem where refrigerator section gets really warm but freezer still works "ok".This is a very common problem.Get us a model # and we can narrow down what it might be.Don't throw away the machine.Easily fixed.
If freezer is not freezing well but there is still refrigeration, the compressor is still probably ok,but there is some inefficiency going on.Most comonly condenser fan off or very dirty condenser coils or bad door seal leak or thermostat system keeps shutting machine off too much.A refrigerant leak would be terminal and you would have 0 refrigeration .
Much to ponder
Repost with more info if you need more help
Hope thi makes you feel better
Aug 22, 2011 | Kenmore Side by Side Refrigerator
My refrigerator is not cold. Freezer seems OK. It's a 2006 Kenmore side by side. Repairman came and cleaned the evaporative cooler and the condenser. this did not solve the problem. Sears repair is so...
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check evaporator fan in freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If this was helpful please rate me
Thanks for using fixya
Leo Ponder
imufo2
I've included my article on fixing refrigerators for your general help.
Please click below.
And don't forget to help me out by VOTING for me
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Jul 24, 2011 | Kenmore Side by Side Refrigerator
My Kenmore side by side freezer is so hot on both sides I can hardly touch it.What can i do?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Jul 24, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer door is leaking water on refrigirator model # frs20zshb5 the freezer side of the body where the magnetic strip touches the door is hot to the touch
You know, it's really normal to touch it hot on the door side.
Because it has heater to eliminate moist build up that can cause rust.
Check the drain pan (that is full of water) for clogged.
Unclog it using flexible solid wire and insert it on drain pan tube.
After that, those leak will be minimize.
Thanks for asking.
Jun 29, 2011 | Frigidaire Freezers
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
