Question about Goodman Manufacturing Goodman CAPF3636A6 Goodman 3 Ton, Cased Evaporator Coil W 14 x D 21 x H 26
I have a model number and need to know how many BTUs.
Performance
Tonnage
2.5 Tons
Nominal Cooling Capacity
30000 BTU
Dimensions
Goodman CAPF3030B6 CAPF 2 5 Ton Upflow Downflow Coil Cased
Sep 19, 2017 | Optics
What it means 450 PSI on ADP evaporated coil
THIS WOULD BE THE TEST PRESSURE AT FACTORY. UNDER NO CONDITIONS SHOULD NOT EXCEED THIS PRESSURE!
Jul 10, 2014 | Goodman Manufacturing Goodman CAPF3642C6...
Overflow pipe
In most cases, they do not come with a overflow valve, That is a addon that most companies install when they do the install. They can be purchased from most ac suppliers I recommend the SS-2 or SS-1 safety overflow switch, comes with two wires you can tie into your low voltage wiring to your thermostat.
Hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Jul 06, 2013 | Goodman Manufacturing Goodman CAPF1824C6...
What is the correct size for evaporator coils piston ?
.078 is Shipped with Coil
Note: For a properly matched system and piston sizing information, refer to Goodman piston kit chart of the corresponding Goodman
outdoor
unit.
Oct 26, 2012 | Goodman Manufacturing Goodman CAPF3642C6...
Updraft evaporator pan cracked and leaked at male hose bib
Yes its possible to break it. Takes alot of force usually only happens during shipping due to hard fall.
Aug 29, 2012 | Goodman Manufacturing CAPF Cased...
I have a goodman cased evap coil that has a cracked drain pan...the service tech wants to sell me a $900.00 evaporator asm telling me that the drain pan cannot be replaced or repaired.
All you need to buy is a drain pan. Although depending on how your evap coil is encased you may have to pull the evap to get the drain pan in.
Aug 05, 2011 | Goodman Heating & Cooling
I have a SSX140241A - 2 Ton 14 SEER R410A Goodman Air Conditioner Unit with a CAPF1824A6 - Goodman 1.5 to 2 Ton Cased Evaporator Coil. The coil came with a size 59 piston and the outside unit had a size 55...
No, it simply has to do with the fact that the conditions are exceeding the innate capabilities of the unit. Need more refrigerant and larger condenser and evaporator. Basically, a bigger, more powerful unit for the conditions encountered.
Sep 22, 2017 | Heating & Cooling
Mounting and securing a cased coil on a Goodmam upflow furnace
yes you use sheet metal screws and than use Foil tape, works better than caulk imho.
Nov 02, 2008 | Goodman GMS90703BXA Heater
Goodman Manufacturing Goodman CAPF3636A6 Goodman 3 Ton, Cased Evaporator Coil W 14 x D 21 x H 26 Logo
19 people viewed this question
Top Goodman Manufacturing Heating & Cooling Experts
Robbie Daniels
Level 1 Expert
zephyrusd
Level 1 Expert
snowmanii
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
