Question about Refrigerators
Lec fridge freezer t2855w
Fridge to cold
4 Suggested Answers
SOURCE: Lec Elan Fridge Freezer: Freezer
Check freezer door seal
Regards, Barry
Posted on Feb 26, 2009
Sea Breeze
  • 4654 Answers
SOURCE: lec fridge freezer, after moving fridge location to new home, fridge compartment no longer cold , freezer compartment working fine.
Ibelieve you sent me the compressor model number MB98NBEM Look around the inside of the doors for model number. ClickHere=> LG UK Home AppliancesLightwave OvenMicrowave OvensRefrigeratorsTumble DryersVacuum CleanersWashing Machines
This is a MB98NBEM
Look insider doors or ask LG by clicking the links above, Thanks Sea Breeze
Posted on Nov 15, 2011
  • 230 Answers
SOURCE: how to fix lec l5026w fridge on top of freezer?
There should be brackets that would attach to the back of both to hold them together and in place, similar to a stackable washer and dryer
Posted on Sep 07, 2012
LEC Tn216 Fridge Freezer is freezing my food
is that not what freezers do . read you manual and adjust the temp settings
Apr 27, 2015 | LEC Refrigerators
What is wrong with a LEC T2855W Freezer that will not maintain its low temperature?
Main reason is loss of gas means you have a gas leaking in the system requires technician to confirm.
Jun 22, 2014 | Refrigerators
Lec fridge-freezer TF5089 faulty door light switch - how do I remove the switch from the fridge to check it?
Prying it out is the only way I know of. When you get it partially out you may be able to get hold of it with waterpump pliers or regular slip-joint pliers adjusted for a wide grip, and pull it the rest of the way out. They are made to be removed this way, so it shouldn't be damaged. If you push in the button and the light remains lit your refrigerator section may not be getting cold, because a bad door switch can send out a signal that the refrigerator door is open, in which case the freezer may not be blowing cold air into the refrigerator section. The door switches are fairly cheap online, especially compared to a service charge.
Mar 22, 2014 | LEC TF50152W White 172 l Fridge Freezer...
How to fix lec l5026w fridge on top of freezer?
Sep 07, 2012 | LEC Refrigerators
Plugged a new tumble dryer into an extension lead in garage with my lec fridge freezer and blew the fuse,brought new tumble dryer inside house and is working fine,lec fridge freezer in garage now showing a...
you have more than likely ruined the control board on the refrige,a dryer and refrigerator should each be on their own dedicated circuit,they use an enormous amount of current to start, and even if one is running and the other starts thats enough to trip even a 30 amp receptacle, and furthermore extension cord use on these types of appliances even a large gauge cord i.e. 12 ga. that will carry 20 amps is not even a good idea because of voltage drop,as this causes motors to draw excessive current and over heat the motors and reduce appliance efficiency too
Nov 09, 2009 | Freezers
LEC Fridge Freezer
clean up your condenser it's gotta be dirty and check your thermostat put it on the coldest setting and check your freezer fan.
if t ain't running check to see if wired with defrost thermostat if it is suspect it defective.
Dec 17, 2007 | Freezers
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
