Question about Breadman Tr2500bc Ultimate Plus 2-pound Stainless-steel Convection
Breadman ultimate plus pan paddle will not spin but machine paddle is spinning
The paddle shaft seems to have seized, can it be fixed? Or where can I purchase a new pan?
  • 3 Answers
SOURCE: circular clip holding paddle axle in place
I fixed this by using an "e-clip". You can get e-clips at any autoparts store, or online in assortment kits for cheap money. You have to remove the spring seal and washers inside the pan, you also have to remove the circlip on the bottom of the paddle shaft, you have to install the paddle from the inside once you have the right size e-clip installed.
It's a lot harder to explain than to do, once you get it apart you'll see how things go together. I have no clue what originally used to hold the shaft in, mine made sqealing noise, when I took it apart there was little left of the original part.
Posted on Aug 07, 2008
jyackle5
  • 8197 Answers
SOURCE: LOst paddle for BreadMan Ultimate Plus
This is the only place I can find one for you.
http://www.ioffer.com/i/BREADMAN-MODEL-TR2500BC-KNEADING-BLADE-PADDLE-TR-2500BC-81561176
Good Luck and please Rate
Posted on Jan 19, 2009
SOURCE: Paddle
Call Maxim at 1-800-233-9054 for a replacement paddle for the Breadman 2500.
Posted on Jan 22, 2009
  • 134 Answers
SOURCE: Need replacement pan for Breadman 2200
Hi
You need to go here for spares
https://secure.prodregister.com/prodprotect/applica/bm.shtml
Posted on Feb 14, 2009
SOURCE: Need a replacement pan for a Breadman Ultimate
Did you ever find a replacement pan? If not, I have a brand-new one.
Posted on Nov 26, 2010
Piece that connects to motor and then paddle fell out
Yes, the C-clip holds the shaft for the paddle in place. I think the only relevant replacement part is the entire pan. Expensive!
Dave Kristol
Mar 23, 2017 | Breadman TR2500BC Bread Maker
Paddle axle fell out the bottom on the pan while washing.
I looked through the manual for this unit and you need a more comprehensive parts drawing showing the drive details. They do not have this kind of detail on line, my advice is to contact them directly by phone.
http://cart.russellhobbs.com/consumer-services/warranty.aspx?sid=BreadmanUS
Nov 10, 2013 | Breadman TR2200C Ultimate Bread Maker
The kneeding paddle is no longer smooth.where can
If the paddle is sticking it could be the sealed bearing on the bottom of the pan is sticking. Either that or the belt is loose and not allowing the paddle to spin freely.
Hank
Feb 08, 2010 | Breadman TR2200C Ultimate Bread Maker
It seems the motor on my Breadman Ultimate 2200C has burned out.
If the motor shaft is not spinning with the bread pan out of the machine it could be the belt has fallen off the pulley, or has snapped. The belt and pulley are inside the base of the machine. Hank
Jan 21, 2010 | Breadman TR2200C Ultimate Bread Maker
The paddle does not rotate
Hey Alex,
It could be 2 things. Take out the bread pan and see if you can spin the paddle by hand. If you can't then the sealed bearing on the bottom of the pan is frozen or failed. Fill the pan with warm water and soak it. If after a few times you still can't turn it, then it's history. New pan is needed. If it does spin freely then keep the pan out of the machine and run a kneading cycle. Look through the lid window to see if the motor shaft is spinning. If not it's probably the belt fell off or has snapped. Hank
Dec 12, 2009 | Welbilt Kitchen Appliances - Others
Sunbeam 3500s
It seems the kneading paddle isn't spinning. Clean out the pan and take it out of the machine. Put the paddle on the shaft and see it it spins freely. If it does not, then the shaft is stuck or the bearing is frozen.
Next keep the pan out of the machine and start the bread maker up. Look through the clear top and see if the shaft is spinning. If not then the drive belt is broken.
If paddle is okay, and belt is okay, then the motor is broken.
Hank
Aug 25, 2009 | Sunbeam Kitchen Appliances - Others
Hi
Feb 02, 2009 | Breadman TR2200C Ultimate Bread Maker
Circular clip holding paddle axle in place
Aug 04, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadman Ultimate Plus pan won't stay put.
you may need a new paddle, because of wear and tear.
Here is a link ahere you may be able to purchase.
http://www.nextag.com/breadman-tr2200c/search-html
Mar 04, 2008 | Kitchen Ranges
Breadman Tr2500bc Ultimate Plus 2-pound Stainless-steel Convection Logo
20 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
