My cannon ir 2570 ci color copier is showing error code e000732-0001 please give me the solution
Cannon ir2570ci color copier shows error code e000732-0001
5 Suggested Answers
SOURCE: cannon ir 6000 ver 8
my copier show error for E601.Than i am change hard disk.now display only download mode.i want ir 6000 version 8 flash software. please help me....
Posted on Nov 21, 2008
KyoDoc
  • 38 Answers
SOURCE: Canon copier ir 3100 cn error code E000602 - 0202
the hard drive containing the software that drives the machine has an error. Corrective steps would be to contact to a Canon technician, who can first try to re-install the software, and if this doesn't work the hard drive has probably crashed, meaning that the drive will need to be replaced and the software re-installed
Posted on Jan 23, 2009
Cogz
  • 1326 Answers
SOURCE: Error code : E 604 of Canon IR 400
It means that you are having a problem with the hard drive boot up program... You will need to replace the hard drive.
Posted on Mar 02, 2010
canontech
  • 1219 Answers
SOURCE: Canon IR 3100cn Copier Error Code E00002-12
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to
reach 70 deg C within 180 sec after
reaching 50 deg C.
Check on connection of the thermistor, Replace the
fixing unit
To recover from the error: In service mode ( * 2 8 * )
COPIER>FUNCTION>CLEAR >ERR
0003 The non-contact thermistor fails to
reach 100 deg C within 180 sec after
reaching 70 deg C.
0004 The non-contact thermistor fails to
reach 120 deg C within 180 sec after
reaching 100 deg C.
0005 The non-contact thermistor fails to
reach 140 deg C within 180 sec after
reaching 120 deg C.
0006 The non-contact thermistor fails to
reach 160 deg C within 180 sec after
reaching 140 deg C.
0007 The non-contact thermistor fails to
reach 180 deg C within 180 sec after
reaching 160 deg C.
0008 The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
0101 The non-contact thermistor fails to
reach 120 deg C within 300 sec after
power-on.
0102 The non-contact thermistor fails to
190 deg C) within 300 sec after reaching
120 deg C.
Posted on Jun 16, 2010
I have IR Canon 2420 copier machine it shows E000007-0000 please help me what is the problem Thank yoyu
as the error codes are cannon specific I suggest that you contact a canon service dealer and ask them what the codes mean
Sep 03, 2015 | Canon Office Equipment & Supplies
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
How can i identifying canon printer ir 2570 ci on my computer ?
What operating system are you using? Can't really help you without you giving us some more details, please.
May 05, 2014 | Canon Office Equipment & Supplies
Error code e000020-02a2
i have canon ir2570ci but shows error code E000020-02a2
Aug 31, 2013 | Canon imageRUNNER C3170U Color Copier
Cannon 3200 when machine has warmed up error code 000732-001
This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
May 07, 2017 | Canon imageRUNNER C3200 Color Printer
E351-0000
E351: Error PCB ECO. Communication error between the PCB and the PCBECO main driver during startup.
Turn off main power and check the main controller PCB (primary, secondary), thenturn the main power.
Check in the back of the machine the main controller PCB (Main) make goodconnection with the PCB ECO-ID: help with image processing.
Hoping this is helpful message ... GOOD LUCK
Apr 28, 2012 | Canon Office Equipment & Supplies
My cannon ir 3300 machine show me Error code E 000530-0000 from last 2 days please give me solution for emergency
My cannon ir 2200 machine show me Error code E 000530-0000 from last 2 days please give me solution for emergency
Sep 09, 2010 | Office Equipment & Supplies
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
k24674
jasbo
jasbo
