Question about Huawei Unlocked U8860 Honor White 1.4g 8m0.3m Dual Camera Android 2.3 4g Rom
HOW TO FIX THE SENSOR ON MY PHONE - Huawei Unlocked U8860 Honor White 1.4g 8m0.3m Dual Camera Android 2.3 4g Rom
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Calibrate your sensor. goto settings of your phone and check for the menu showing your menu for sensor
Posted on Jul 22, 2013
Repair proximity sensor in iphone 4 and vibration not working.
This problem was caused by the light through the 2 holes of the glass.You can cut a black tape with 2 holes, and cover it on the sensor flex cable. It can resolve your iPhone 4 Proximity Sensor Not Working problem perfectly.
Jan 22, 2013 | Cell Phones
HTC HD7 going blank on calls...
I had this same problem. There could be a few reasons. Starting with the simplest:
Finger placement; sometimes your fingers may wrap around and touch the screen while using it causing the proximity sensor to turn the display off.
Screen protectors; I got lucky because my problem was being caused by the screen protector i was using. It had come off a bit in my pocket and gotten scratched on the part that touches the screen which messed up with the proximity sensor. All i had to do was take off the protector and the problem was fixed.
Sensor Malfunction; The proximity sensor in the phone is malfunctioning and you can try to hard reset the phone but usually if it is malfunctioning you just need to get it fixed or replace the phone. If your phone is still under warranty you should probably use it.
Jun 10, 2012 | HTC HD Windows Phone 7
I have a gt-b310, but the touchscreen has stopped working. Cant see any damage to the screen... Any ideas how to fix...
If the touch screen of your phone stops working. Since you have confirmed the fact that the screen is not damaged, then it is quite obvious that the problem is from the touch screen sensor board. If the sensor board is bad then it means the screen wont be responding to any for of touch.
The solution to the problem is for you to replace the sensor board. That should solve the problem for you. You will have to disassemble the phone and resit the flexi ribbon that connects the screen to the phones main board.
Thank you for using fixya.
Caseytech
Sep 02, 2011 | Cell Phones
Touch screen is not working, how do i go to menu, shortcut key to menu.
There are no shortcut keys to the menu option except you stored them yourself. But since you o not have any shortcut key to the menu, it simply means you just have to fix the phone.
There are two major reasons that could be causing the touch screen not to be responding. The first is if the phone fell and the sensor board got bad, and the best solution is to replace the sensor board. To replace the sensor board is quite sensitive so i will strongly advice you seek advice from a specialist that can assist you with that. But if you intend to fix it DIY way, then you can ask and i will direct you through the steps.
On the other, it might be the screen is weak and needs calibration. To calibrate the screen depends on the type of phone it is. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Caseytech
Jul 06, 2011 | Samsung SGH-A877 Impression Cell Phone
Themes..motion sensor games for lgkp500
there aren't any themes or motion sensor games (except the ones that come with the phone)
but for themes, there is an application that let's you use special themes.
go to www.mylgcookie.com, then the themes section.
Hope this helps
Apr 02, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Remote sensor does not work on my 27" crt panasonic tv. Is it worth fixing? How much will it cost to fix?(approx.)
test your remote first by placeing in front of a cell phone camera and press any button on the remote and look for a blinking light on the cell phones lcd screen (same as taking a picture) if you the blinking light then your infrared remote sensor is bad inside the tv. part cost about 10 dollars.
Mar 19, 2010 | Panasonic CT2722H TV
Have it motion sensor games
there aren't any motion sensor games for kp500, except the ones that come with the phone...
but there are many touchscreen games, and some are for kp500 (rare)... this website for games : www.mobile360.org
Mar 06, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Dead phone
Fix Ya,
The problem is not fixed, my husband bought me e new phone. I would not bother to have it fixed, it's so dead..............
Sep 30, 2008 | GE 27928GE6 Cordless Phone
Trying to fix my samsung
when the phone gets wet, it never runs good again. the phone may work for a while but it will shut down after time
Apr 27, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Cell phone
if you are good at opening then just open and check the keypad sensor might have got displaced ... if so then correctly place it ...
or may be the key pad buttons are not in contact correctly with the sensor board ...
if so just place it correctly & check whether the keypad is right or not ... if not replace with the good one ...
it will surely work ...
Mar 31, 2008 | Cell Phones
Huawei Unlocked U8860 Honor White 1.4g 8m0.3m Dual Camera Android 2.3 4g Rom Logo
51 people viewed this question
Top Huawei Cell Phones Experts
Aaron Galvan
Level 1 Expert
Phillip Whisenant
Phillip Whisenant
Kenneth Walker
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
