Question about Audiovox PPC 6700
Text Message alert???
I need an alert that is longer and louder than all the ones that are available when I recieve a text message. You can add ring tones for incoming calls, butr cant seem to add them for text message alerts. Can anyone help???
  • JPatterson87 Mar 02, 2008
    I have the same issue with the tones that are on the phone for text messaging not being loud enough, or a long enough duration for me to notice when it is going off. I have downloaded .wav files to my phone that can be used as ring tones for incoming calls, but they do not show up in my dropdown list for tones that can be used for textmessaging alerts. Can someone PLEASE help me...
    Thanks...
    Jo
  • 67 Answers
In order to use tones other than the presets for text messages, you have to put new .WAV files on your phone. Any 8bit .WAV file will work; just connect with ActiveSync and navigate to your /Windows directory on your phone, and place the files there. You will then be able to use them as text message alert tones.
Posted on Sep 07, 2007
TEXT ALERT
I use SMS Popup (from the Play Store) for repeating text message reminders. It has other functions, but I primarily use the 'reminder' options. I'm not sure if you could (or should) do 5 to 10 second intervals as it would probably kill your battery. I think that 1 minute is the minimum. I guess you could also use a notification sound that is longer. You could even record your own. I once recorded myself coughing and used it as the notification.
Feb 08, 2014 | Samsung Cell Phones
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
I cant set a ring tone for a text message.
Go to Menu, Setting, Sound Profile, select profile, I prefer Normal, go to the drop down menu (you should see Call), select Message, go to Message Alert Type and choose Melody, go to Message Alert Tone and touch Tones (bottom right corner) select the tone of your preference, press Add and Save... have a Blessed day!
Oct 08, 2009 | Samsung SGH-A877 Impression Cell Phone
Sound problems
try hard reset, but do a back up as it'll wipe out all data on your phone.
Aug 22, 2009 | HTC FUZE Smartphone
When I recieve text messages my Lg xenon ''talks'' . For instance it will say ''message from ...'' I can not figure out how to turn this message alert setting off, I have looked everywhere on the phone but...
You need to disable Call Alert in your Voice Command settings...go into menu - settings - more - application settings - voice command. The last option on the list will be Call Alert, change to ring only.
Jul 31, 2009 | LG Xenon GR500 Cell Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
When a new text or call is says Message/Phone call from....."
Go into phone settings, then voice commands, then call alert. Set it for ring only. I have the EnV2, so it could be a little different, but thats how i do it on my phone. Good luck.
Jan 29, 2009 | LG enV VX9900 Cellular Phone
Cant get message alert to shut off when volume is loudest
you will need to assign the ring tone to the ring of the phone.
Dec 05, 2008 | LG RUMOR Cellular Phone
Motorola i530 text message notifications
u need to go in to your sound setting go on to message tone looks like its set on silent then u will be able to hear it when it goes off
Jan 14, 2008 | Motorola Mobility i530 Cellular Phone
Text alerts
pleace go to your phone menu and then select profile and open it then you see ring tone,ring tone volume,massage alert,massage tone,etc open massage alert and off it.
Jul 23, 2007 | LG CG225 Cellular Phone
Audiovox PPC 6700 Logo
316 people viewed this question
Top Audiovox Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
Martin Murray
Starnley Johnwells
Starnley Johnwells
Are you an Audiovox Computer and Internet Expert? Answer questions, earn points and help others
