Question about Dishwashers
Dishwasher size cata DW160
Water not draining after wash
  • 1462 Answers
SOURCE: dishwasher will not drain water out
if plumbed in under the sink, check the spigot the drain hose goes to is not blocked - a common problem. if on drain you should be able to hear the drain pump working. if you hear a faint humming noise instead, then there is probably a foreign object stuck in pump. also check for blockage in the drain hose
Posted on May 06, 2007
  • 641 Answers
SOURCE: Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
Posted on Jul 27, 2007
  • 7 Answers
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Posted on Nov 02, 2007
SOURCE: GE Dishwasher is not draining water
GE Prifile dishwashers have a valve called a "Piston" and an "O" -Ring under the screen that become degraded over time. The part is around $10 and it takes about an hour to do the repair. You can do this yourself if you are handy and have some simple tools. You can go to the GE website and get a free owners manual.
Posted on Aug 01, 2008
  • 3 Answers
SOURCE: Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Posted on Apr 23, 2009
I have a cata dishwasher that fails to wash dishes correctly and has stopped heating up to dry the dishes. Any suggestions??
kilpaddy84, did you resolve this issue with your Cata dishwasher as i have the same issue?
Jan 17, 2012 | Dishwashers
Slow or no drain of water. cleaned out sump covers and ran drain cleaner thru cycle. looking for possible secondary filter.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Hope it helps...
Jun 27, 2011 | Hotpoint Dishwashers
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Jun 25, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Wtaer will not drain. what are things to check.
Hope it helps...
Jun 24, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Kenmore dishwasher won't drain. Can hear motor trying to cycle but it sounds like it's locked.
Hope it helps...
Jun 23, 2011 | Dishwashers
Will not drain
Jun 23, 2011 | Thermador DW44Z Built-in Dishwasher
My kitchenaid kudv24 will not drain water out
Jun 21, 2011 | KitchenAid 24 in. KUDS25SH Built-in...
There is water pouring out of the snorkal on my kitchen sink every time I turn the dishwasher on. How can I fix it?
Hello there:
There are 2 possible reasons this is happening .
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Oct 05, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Thank you !!
Jun 04, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
MY DISHWASHER WON'T DRAIN ALL THE WAY WATER STAYS IN THE BOTTOM
Hi
If the water doesn't drain from your dishwasher, check these---
Drain line/air gap -- Clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump-- Dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--It is a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid--Dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly.
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 29, 2009 | Dishwashers
Dishwashers Logo
618 people viewed this question
Top Dishwashers Experts
