Question about Garden
How to remove spindles from my kubota T1600 mower deck
Spindles are stuck
  • 376 Answers
SOURCE: How do I remove the spindle from the deck of a Craftsman mower.
Put your blade back on so you will have some backup on the nut. Wedge a piece of 2x4 between the blade and deck to hold the shaft while you take off the nut. You should do that before unbolting the spindle. If you are just replacing bearings, you don't have to unbolt the spindle at all. Just remove the pulley on top and the shaft with blade attached will slide out the bottom. The botton bearing, however, will be on the shaft and is difficult to get off. I use a bearing splitter to get it down far enough to drive off the shaft.
Posted on Jun 15, 2009
wadembly
  • 475 Answers
SOURCE: How to replace lower deck spindle bearing on my
take the deck off or take the belt off of pulley there is a nut on top of pulley loosen nut with a brass hammer hammer it down & it should drop the spindle out to replace bearings
Posted on Jul 09, 2009
  • 257 Answers
SOURCE: Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Posted on Aug 15, 2009
  • 138 Answers
SOURCE: remove pulley on mower deck spindle
These are generally held on with just one large nut, I recommend you use a impact wrench otherwise it mau prove difficult ( you wont be able to hold the spindle tight enough) and certainly you will need a impact wrench to reassemble the spindle
Posted on Aug 22, 2009
  • 138 Answers
SOURCE: deck is leveled, blades are fine,spindle not bent it still cuts
there was a problem with the lighter gauge decks [thinner steel], and the deck would actually bend inward on the left side. this would tilt the mandrel inward making the blade cut at a slight angle to the right blade - there is tool to straighten the deck [the left mandrel housing usually breaks, though] - some shops have this tool, others have never heard of such a thing - most sears l&g field techs have this tool in their trucks - i have the tool in my shop, but i have had luck with turning the deck over and whapping it a couple of times on the inside edge of the left mandrel until the blades line up
Posted on Aug 26, 2009
Kubota T 1460 Need belt size for deck and belt going to Engine
kUBOTA FOR T1460 SN 40001 AND UP
K5112-71410 DECK BELT
K5112-51310 ENGINE TO DECK
Cross reference shows both to be 5/8 x 69 Kevlar belts
Apr 17, 2015 | Kubota Garden
Do you have free manuals of Kubota mowers?
Try requesting manuals directly from Kubota.
Jul 16, 2014 | Kubota Garden
Main spindle needs replacement how to
Typical Kubota mower spindles are mounted with 4 bolts. Some have 4 more on a larger support plate. First the belt pulley must be removed, possibly with the help of a jaw-type puller. Then remove the 4 bolts around the perimeter of the spindle. Using a soft mallet or wood block, drive the spindle assembly down through the deck, making sure there is room underneath for it to fall. Kubota sells replacements as complete assemblies which saves a lot of time vs. rebuilding the spindle.
Oct 05, 2013 | Kubota Garden
Kubota t1600 mower
Its easier
Jun 08, 2013 | Garden
How to replace the spindle on a 48 inch mower deck
OK, Now I see your question under a different post. You are going to have to pull the deck out from under the spindle housing and spindle and replace them. They usually come as an assembly. after removing teh deck you should see the spindle housing retaining bolts to remove. Make sure you pull the blade off that spindle before you try removing it.
Oct 02, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I need a kubota hst t1600 manaul pls
I just bought 1 for a t1400 at the dealer for $48.
Jun 05, 2010 | Garden
Smoke coming out when i engage the blades
Most likely the mower belt is rubbing and causing this. But don't try to find it with the mower running! With the engine off, lower the deck and inspect the mower belt for worn or burnt spots. The problem isn't the belt, though. Look under the mower deck - is a branch or other object stuck in there? Get it out, and replace the belt if it's badly burnt.
If it's not a stuck object, than you probably have a frozen spindle (the bearings that hold the mower blades) or idler pulley. Remove the belt and spin each of these by hand to find the problem. The pulleys are not expensive, but the spindles are. I hope it's just a branch. Good luck! Please rate if helpful, thanks!
Jun 04, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to remove blade pulley on a kubota RCK40LT mower deck
To remove the two smaller single blade pulleys you will need at least a 5 inch bearing puller (the kind with three legs. There are two sets of bearings in both assemblies, one on the top of the spindle shaft and the second at the top. If you plan on removing the double pulley in the center that takes the power from the engine and transfers to the blades you will need at least a 6 inch bearing pulley. My recommendation is replace all the bearings, cheap insurance in my opinion. Keep notes of what, where, how each item is removed so it goes back in the right place.
May 09, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Garden Logo
156 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
