Question about LG WM-2277HW Front Load Washer
Bleach dispenser symbol - LG WM-2277HW Front Load Washer
What do the dispenser symbols mean?
bleach if you don't have a bleach dispenser on your washing machine. ... That means that if you add your chlorine bleach as stated above you will not get bleach...
Sep 04, 2015 | Washing Machines
Which compartment for bleach?
Good Morning Friend,
I understand that you want to know which opening in the dispenser is for bleach on your Electrolux washer, model# EIFLW55I. The compartment where you will put bleach will be labeled "Liquid Bleach", and will also have a symbol of a triangle with the letters "CL" inside of it. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Electrolux EIFLW55I Washer
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Duet Bleach dispenser not working - dispenser motor working properly
It sounds like the solenoid output of the bleach dispenser may not be reacting to the step motor that cycles it...Also check for a clog of dried out stuff just below the dispenser screen.
Dec 31, 2012 | Whirlpool duet Washing Machines
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Finished Clean Washer cycle and my bleach dispenser full
It's normal for all washers with a sanitize or tub clean cycle to leave diluted bleach in the dispenser
Feb 11, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Bleach and Fabric Dispenser not working
Got a Brand new LG ~ WT5001CW toploader today. I did 2 loads of wash. Theres a Bleach Dispenser on the top left side but I didn't use it. In the middle of my 2nd wash I noticed the bleach dispenser was full of water. I thought well maybe after the rinse and the spin it would take the water out. Well when the cycle was complete the Bleach Dispenser was still full of water.
I took the Bleach dispenser out and checked the holes to see if anything was plugged, didn't look like it. Was wondering if anyone knew how to solve this problem or do you think that since I took the bleach dispenser out and put it back it that it might work for my next load ??
Any opinions will be greatly appreciated !! Thanks Much !!
Apr 26, 2009 | LG Washing Machines
Kenmore/Sears 417.43142200 bleach dispenser not dispensing
Before you do anything, make sure that the plastic part in the bleach dispenser container is pushed in. Fill with bleach to the "max" line, written on the plastic part. Start the wash cycle and make sure that water goes into the bleach dispenser. Once water flows into the dispenser, the bleach/water mixture rises and should automatically dispense into the washer. We had this same problem. We removed the dispenser unit and took it to the sink. We then filled it with water and it started coming out from the bottom automatically. So sort of suction is caused from the amount of water and it starts to flow. Basically, you aren't adding enough bleach into the dispenser if the water flows into it as the wash cycle runs.
Mar 22, 2009 | Kenmore 43142 Front Load Washer
Whirlpool bleach dispenser not dispensing properly
It sounds like the bleach dispenser is clogged or has a crack in it. What we do, is when we bleach our clothes and I know that this is extra work, but we wait until the washing machine is full of water, then add the bleach directly to the wash.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Bleach dispenser
RU SURE ITS NOT WATER NOT BLEACH ,,THERE WILL ALWAYS HAVE WATER IN THAT DISPENSER
Nov 25, 2008 | Washing Machines
LG WM-2277HW Front Load Washer Logo
16 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
