Question about Garden
Sears model 143.006706 gas engine/mower
After blade strike, engine will not start
  • 3 Answers
SOURCE: Blades will not engage
Lever that adjusts height does not make blades turn. You need to engage the blade lever and if you can not tell if the blades are turning then they probably aren't. check belt it could need replacement.
Posted on May 12, 2009
  • 202 Answers
SOURCE: Sears Riding Mower stops running when the blade is engaged
check the deadman sensor under or in the seat. if it don't "see" you on the seat then the mower will shut down. good luck and hope this helps
Posted on Jul 27, 2009
  • 95 Answers
SOURCE: I would like to replace the mulching blades on my
The straight blade for the 42 inch mower is 138971.They cut better and are easier to sharpen and you will need them if you use a gass catcher. If you do not want to use sears for parts you may be able to find good deals on ebay.
Posted on Jul 30, 2009
mowerman1857
  • 389 Answers
SOURCE: When I put the mower in gear, or engage the
Sounds like the seat safety switch is shorted or worn out. You can test it with a short length (about 6") of wire. Strip about a half inch from each end of the wire, unplug the connector under the seat and plug your "jumper" wire in to each side of the connector (NOT the seat switch) If it now works, replace the seat switch
Posted on Sep 16, 2009
Testimonial: "Thanks. The problem was the seat safety switch was loose and not fully engaged. When I plugged it in correctly, everything worked!!! Thanks again."
emissionwiz
  • 76649 Answers
SOURCE: sears craftsman rider mower model #917.276815 will
WHAT U NEED TO DO IS GET A CAN OF SPRAY STARTING FLUID (ANY AUTO PARTS STORE, VERY CHEAP) AND SPRAY IT INTO THE AIR INTAKE OF THE ENGINE, CHANGING THE SPARK PLUG ISN'T GOING TO HELP HERE, SPRAY THE STARTING FLUID AND ONCE IT IS RUNNING THE PROBLEM WILL CLEAR UP MOST LIKELY.
Posted on Apr 05, 2010
Where can I purchase replacement blades?
Hi Jim, you can buy replacement blades for your riding mower at most hardware, or lawn and garden store. I believe Sears home and garden has them also. They are the same as a regular push mower blade, but smaller because you have 2-3 blades. I'll put a link to help you out. All you really need is the model of your mower, and blade length.
Sears com
Aug 17, 2015 | Garden
When you whack something that hard and the engine stops immediately 99% of the time you sheared the Keyway between the Flywheel and the Engine crank. When this shears, the flywheel shifts which throws off the Ignition Timing. You need to take off the Recoil starter and then take off the Flywheel, Any small engine place will have a keyway replacement. The keyway Cost pennies
Jul 21, 2013 | Cars & Trucks
Sears riding mower will not start after it killed.
first thing you need to do is check and make sure the blades are disengaged set the park brake and try to start it again all newer mowers will not start without parking brake set or depressed and blades or pto in the off position good luck
Oct 07, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
The engine starts and runs fine. but when I try to engage the blades or release the clutch the engine tries to go dead like a saftey switch is bad
Its called a PTO switch.
Visit www.searspartsdirect.com and enter your full model number for a breakdown of parts and ordering options.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What is the part no. of the blades on a 42 in. mower
You can go to Sears' website at www.partsdirect.com and enter your model # (usually found under the seat) to view the diagrams for your model and locate your part #'s. Once you find the Sears #'s, you can find replacement blades for your mower at Partsbuggy's Sears page here - http://www.partsbuggy.com/ope/ayp_roper_searsmower_parts.htm. It also lists Sears' part numbers along with the blades and belts by deck size.
Jul 06, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
I need to find mounting bolts, blade to shaft
Do you meanengine mounting bolts, blade boss, and 'Operator Presence Control' cable? If so, they are generic parts - not specific to your mower. I have no idea why you are having problems ordering them - they are consumable parts, and should be stock items for ant garden machinery repair outlet.
Aug 06, 2009 | Craftsman Garden
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
I would like to replace the mulching blades on my Sears Craftsman riding mower with regular cutting blades. I can find plenty of sources for new mulching blades, but not cutting blades. My mower is a model...
Jul 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a sears 19.5 42in cut - Model #917.270810 need to find part for a spindle (I think it is where the blade attaches to.
sears has a appliance and tool repair center some where in your area hopefully.with your model # you should be able to order parts from them no problem.try a web search for appliance repair center for sears in your area........gd lk. chris.
p.s spindle is indeed the drive shaft for the blade.
May 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Change rotory blade on craftsman 917377794
This is a nice mower, it has a Honda engine. The blade bolts onto a "blade brake clutch" which is why you see 3 bolts. Removing the two outer bolts should release the blade. Normally these bolts are about 1/4" to 5/16" diameter at the threads, and have split washers to prevent them from accidentally coming loose from vibration or impact.
Here's the steps I use when replacing the blade:
  1. Pull the spark plug wire off the spark plug.
  2. Lay the mower over on it's side (gas filler cap should be up, so whichever side allows the gass filler cap to end up on the high side of the engine).
  3. Find a wrench that properly fits the blade bolts.
  4. If right-handed; wearing a garden or protective work glove on the left hand, grasp the blade.
  5. Unbolt both bolts by turning in a counter-clockwise direction (left circular direction).
  6. Remove the bolts being sure not to lose the locking washers.
  7. Pull the blade off the blade mount (sometimes a light tap is necessary to loosen the blade from the blade mount).
  8. Replace the blade with the exact Sears part number (diagram and parts list attached below).
  9. Thread the bolts back on using your fingers to get them started - don't force them if they start to bind or you'll cross-thread them; bad thing).
  10. Snug the bolts down tight, sufficient to compress the locking washers flat.
  11. Don't overtighten, they need to be tight, but if you use a long handle wrench or ratchet drive you can cause them to break or fail while the balde is spinning, another bad thing. Tighten them snug assuring the washers compressed flat.
  12. Turn the mower back upright onto its wheels.
  13. Replace the spark plug wire back onto the spark plug.
  14. Leave sit for 30 minutes before starting to assure the oil has returned level in the engine before you attempt to start the engine.
Here's your diagram and parts list:
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917377794&productCategoryId=1500600&brandId=0247&modelName=Gas,-Walk-Behind-Lawnmower&diagramPageId=00001&componentDescription=ENGINE/HOUSING/HANDLE/BAG/BLADE&documentId=P0401287&backToLink=Return%20to%20Sub%20Components%20list
Thanks for using FixYa, please take a minute to rate my answer?
Gregg
Apr 02, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
