Question about LG Cell Phones
Warning triangle exclamation mark - LG Cell Phones
  • 67 Answers
SOURCE: vw jetta 2OO7(or O8) lightbulb sign with an exclamation mark?????
this says that one of your bulbs is not operating. check all lights round the car, including the brake lights (have somone to oberatge the brake while you have a look). you will see one not working. replace and sign goes away
Posted on Jun 03, 2009
  • 1986 Answers
SOURCE: Warning light
I believe it has to do with your traction control sensors and that one of the sensors may be faulty
Posted on Oct 14, 2009
ZJLimited
  • 17970 Answers
SOURCE: what does the warning light - yellow circle
Are refer to the Brake System; in RED and YELLOW condition, continue driving cautiously:
More details about this Warning Lights you can find in the 2003 Mini Cooper - Owners Manual (page 16 and next).
I really hope helps with this (remember rated this help) Good luck.
Posted on Jan 08, 2010
ZJLimited
  • 17970 Answers
SOURCE: what does the warning light of a yellow triangle
Standard Vehicle Stability Assist™ (VSA ®) with Traction Control and Brake Assist Vehicle Stability Assist (VSA) is an electronic stability control system that works in conjunction with the Pilot's drive-by-wire throttle and its 4-channel ABS systems to enhance controllability while the vehicle is accelerating, braking, cornering or when the driver makes a sudden maneuver. VSA functions by applying brake force to one or more wheels independently while also managing the throttle, ignition and fuel systems to help the vehicle maintain the driver's intended path of travel.
The VSA system constantly analyzes data from seven sensors that monitor wheel and vehicle speed, steering input, lateral G forces and yaw rate. It compares the driver's control inputs with the vehicle's actual response. Whenever the actual response falls outside of a predetermined acceptable range, VSA intervenes with a corrective action.
For instance, if VSA detects an oversteer condition, the system may apply braking force to the outside front and rear wheels to counteract the unintended yawing effect. In the event of understeer, VSA may apply braking to the inside rear wheel while reducing engine power to help return the car to its intended course. VSA also provides a limited-slip differential effect for the front wheels by applying braking force to a slipping wheel, thereby redirecting driving force to the wheel with more traction.
There is a button on the lower left part of the dashboard that says "VSA". Push it and the triangle will dissappear (this should only be turned off if you are using a spare tire that is smaller than the rest of the tires).
Good luck.
Posted on Mar 02, 2010
smozhe
  • 2360 Answers
SOURCE: mY htc driod is locked
Try unlocking sites
Posted on Dec 17, 2010
What does a yellow exclamation point inside a triangle warning sign mean. Now check engine light just came on.
The yellow triangle with an exclamation mark will typically be accompanied by a message explaining what's gone wrong. Hopefully it will be self-explanatory - such as a low reservoir for the windscreen washer system.
Dec 28, 2017 | Cars & Trucks
Why does my darango shut off while driving?
If it's an exclamation point inside a triangle, it's called a master warning symbol. This is the Master Warning Light symbol. If this light is on, there will likely be text displayed as well on the instrument panel, or another warning light. Look for text in particular. It could very well point out something as serious as low oil pressure. If the engine is not running, you can't very well check your gauges, but you may have lost all oil pressure or overheated the engine. Recommend you consult a mechanic familiar with your model.
Oct 14, 2016 | 2003 Dodge Durango
Yellow triangle with exclamation mark permanently showing
This is the master warning light. It is a warning that another light is lit or a condition has occurred that requires review by the driver. If there is a driver information window a message may be displayed.
Example of other conditions depending on the car is:
  • Low tire pressure
  • low window wash
  • Low fuel warning
26143099-cuwo5vs5donv5atj0gwaggyx-3-0.jpg Hope this helps?
Mar 27, 2016 | Cars & Trucks
What does message check engine with a triangle exclamation mark mean and number 1? Thanks
You don't say what year, brand and model car you have.
The Check Engine (CE) warning and the triangle warning are different.
1. If the CE light is on there are dozens of possible causes but you need to have the car scanned to see what faults have been generated and what irregularities show up in the operation of the engine. Don't delay having it professionally checked out or the computer may send the vehicle into limp mode to protect the engine or the engine may stop altogether and you will not be able to restart it..
2. The triangle with the exclamation mark is normally the traction control (TC) system warning. If this displays constantly the TC may have been turned off manually or (more likely) there is a problem detected with the TC system and it has been shut down by the computer. You will need a scan to see what faults the computer has detected so a proper diagnosis of the problem can be made.
Jan 08, 2016 | Cars & Trucks
WArning light is on. Triangle with exclamation mark inside the triangle. What does this mean?
YOU HAVE ABLED YOUR FLASHER WARNING LIGHTS. LOOK FOR THE RED TRIANGLE ON THE DASH CONSOLE AND PRESS IT.
Nov 17, 2015 | 2006 Chrysler Sebring
What is the warning with a Triangle and exclamation mark inside it
It means "something is wrong". You need to check the messages to find out.
May 07, 2014 | 2007 BMW 3 Series 328i
Exclamation marks is red on dashboard, diagnosis shows code 171 and 174
P0171 System too Lean (Bank 1)
P0174 System too Lean (Bank 2)
So why does another fault light come up when brake pedal pressed ,Try reading the codes again with a diagnostic tester that has the relevant codes built into the machine and not a micky mouse device
Nov 29, 2013 | 1999 Ford Ranger SuperCab
Warning light with triangle with exclamation mark and brake lights apperaing on dash
The waring kight with the triangle and exclamation mark is waring you that the brake pads are close to tuoching the disc's the waring sensor on the brake pad has shorted. It's so you do not scrap the disc's.
Feb 09, 2011 | 2001 Volkswagen Passat
2008 RS 125: red triangle warning light with exclamation mark i...
Hi, Anonymous it's your temperature warning light and I am sorry you can't find the first and best tool you ever bought for your Aprilia but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD 2008 Aprilia Rs 125
May 17, 2010 | 2008 Aprilia RS 125
Cell Phones Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
