Ciac window air conditioner error codes
Error code PP
  • 3 Answers
SOURCE: error code on air conditioner
Search for this problem on web or contact Sharp Technical Support for the following procedure:
1. Unplug unit.
2. Hold down power button while plugging in unit. It will do a short self-test and then beep. leaving unit off.
3. Release power button and unplug.
4. Plug in again and turn on normally. This should last for about 720 hours, at which point the E1 error will come back and you need to follow the procedure again. (You might as well clean the air filter at this point just in case it really needed it...)
Posted on Jun 30, 2009
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
  • 68 Answers
SOURCE: Error code of E4 on Dometic HP air conditioner ??
16. SYSTEM RESET
a. Turn the ON/OFF switch to “OFF” position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to “ON”.
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released.
c. When a dip switch is turned on or off after initial configu
ration, a system reset will need to be done before the
Comfort Control CenterTM will recognize the updated selection. Try this. This is for the five button thermostat. Did you check the dip switches to be sure the proper ones are turned on? I need to know which stat you have 4 or 5 button. I have trouble shooting for both.
If you notice reset needs to take place after a dip switch is turned on or off. The dip switches are on the circuit board. You need to drop the lower cover. the dip switches will read in this order #1 heat strip/ #2 zone2/#3zone3/ #4 zone4/#5 furnace/#6 differential/#7stag/#8 gen start. Check this out and be careful. Turn off the stat to change dip switches. On will be toward the description. If you don't have remote start gen set the dip should not be on. If you dont have a Zone 3 the dip should not be on, etc.
Any questions feel free to post back
Thank you for using fixya
Jerry
Posted on Mar 26, 2009
SOURCE: Samsung AQV12VBA error cod displayed E5 54
Check the freon...
Posted on Jun 09, 2010
SOURCE: E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Posted on Jul 27, 2010
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
Why is e5 showing on my 15000 frigdare window unit
Ive seen ES, in two sites http://www.doityourself.com/forum/air-conditioning-cooling-systems/532071-frigidaire-ac-window-unit.html
http://www.searspartsdirect.com/window-air-conditioner-repair/error-codes/frigidaire-window-air-conditioner-error-codes.html So I'd tend to agree with the majority.
Mar 14, 2015 | Heating & Cooling
WHAT IS ERROR CODE H5 FOR A FRIGIDAIRE HEAT/COOL WINDOW UNIT?
Thank you for your inquiry, Angela Babin!
From my understanding your Frigidaire air conditioner is displaying an error code "H5". Normally, the error code "H5" stands for heater thermistor error. I would recommend performing a reset on your air conditioner by unplugging it for ten minutes. If that does not help correct the error code it could be a possible problem with your thermistor or control board. I hope this is helpfully. -Matt
Nov 02, 2014 | Frigidaire Heating & Cooling
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
Frigidaire fas257q2a2
Hello Friend, I am happy to assist you!
I understand your Frigidaire air conditioner (FAS257Q2A2) is displaying error code A5; however, it appears the correct error code is AS. Error code AS typically indicates that your air conditioner is experiencing an issue with the ambient thermistor. I would strong suggest contacting a professional to check the wiring between the main control board and thermistor. A certified technician would generally replace the faulty part after proper diagnosis. Best regards! - Z
Jul 06, 2014 | Frigidaire FAC125P1A Window Air...
Ciac air conditioner ff error code
FF code means blown or missing damper fuse. Replace damper fuse (inside equipment cover plate) and try again. If damper fuse blows again, find and fix the problem causing the fuse to blow.
Mar 27, 2014 | Carrier Heating & Cooling
Ciac inverter error code "U8
two error codes i get "H6" and "U8" after u8 system will not run at all..carrier is no help and service people have no ideas
Sep 17, 2013 | Heating & Cooling
CIAC High Wall H3 Error. Will not cool.
my CIAC wall mount unit evaporater is freesing what can it be.
Aug 16, 2013 | Heating & Cooling
Ciac air conditioner error 6
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need any other AC Advice. Check us out online. WPB AC Repair
Jun 29, 2013 | Heating & Cooling
Heating & Cooling Logo
473 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
