Question about Radio Communications
Baofeng UV5RA WILL NOT TRANSMIT
Baofeng UV5 RA RECIEVES JUST FINE BUT WILL NOT TRANSMIT..Have programmed it according to manual ..When I Transmit in the Frs bands thr voice comes out garbled lsounding like a space alien but int the 440 mh and 146 mh bands nothing....
    Master:
  • 623 Answers
First, it's illegal to use that radio in the FRS bands. Also many of the Baofeng radios have very "dirty" output (spurs, frequency drift, bad modulation, etc). Your best bet is probably to buy another radio. With these radios about 3 of 10 I've tested have been bad.
Posted on May 04, 2014
5 Suggested Answers
SOURCE: ic w32a
Thanks for letting me post a question.
After taking it apart again I found a pin on the lower board socket that got bent over on reassembly........
Posted on May 14, 2008
SOURCE: Columbia FRS-S14 two way radios
Are you just looking for a way to program them to the same freqs? But if they are FRS family radio then they should have the same channels in them.
Posted on Nov 05, 2008
eradiostore
  • 1654 Answers
SOURCE: can transmit to other frs radios but cannot
Check the "code" (interference eliminator code) on the FR60 and set it to off or zero. It appears from your description the Cobras do not have "code" turned on. Refer to your user guide to find the instructions for turning off the code. (As of this date we have not found an FR60 manual posted online.)
Best regards.
Posted on Dec 06, 2009
Testimonial: "I set interferance code to zero and it works Thank you Ken"
  • 97 Answers
SOURCE: I just purchased two Baofeng BF 888s radios and had them programmed to our frequency here. They will both receive and transmit with each other but not transmit to the radios we already had. Any ideas?
Your radios could be programmed with subaudible tones (CTCSS) or digital code squelch (DCS) which the new radios do not have. They can be programmed for it, you need to find out what tone/code you are using.
It could also be that your existing radios are programmed for a "duplex" repeater channel, with different transmit and receive frequencies. The new radios might be on the "repeater output" frequency so they would not activate the repeater.
Both could be the case, missing tone and duplex frequencies.
I would check the programming of the new and old radios, especially for tone/code squelch.
Posted on Sep 14, 2012
Can a pair of Kenwood TK 3160 work with Baofeng BF888s I have a Baofend and another coworker has the second Baofeng.Our shipping office bosses have Kenwood TK_3160 can they share channel 7
Here goes. Yes, your Baofeng Ham radios could be programmed onto a business band channel. Yes, it could transmit. BUT, ham radios do not meet the stringent requirements that Business Band radios do. This refers to channel spacing, interference and a long list that Business radios are required to have to make operation legal. Therefore, your Baofeng makes a great scanner. Business band frequencies are to be used by radios meeting these stringent requirements in order to prevent interference. Failure to follow the FCC Rules could result in a hefty fine. Didn't you wonder about the price difference?
Apr 15, 2015 | Kenwood Programming Cable Tk2160,tk3160...
I can transmit to my to my baofeng vr6 but i cant reiceve a transmit from it to my icom v85
Check the input output settings.
the baofeng is notorious for being somewhat difficult to program manually.
Try the software setup if possible.
Jan 16, 2014 | Icom Radio Communications
Will not transmit to a repeater
1) are you within range,?
2) is there an obstruction between you and the repeater?
3) do you have the proper PL tome programmed for the repeater?
4) When you press transmit, is the correct input frequency displayed?
Nov 29, 2013 | Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free...
Baofeng uv-5r will not transmit
Sounds like you have the transmit lockout set. this radio is a bit of a pain to program, but is well worth the effort. your best bet is save your settings (backup) and do a full factory reset, and start over, making sure you did not lock out the transmit on any channel or VFO...
Oct 15, 2013 | Dual Uv-5r Baofeng Band Uhf/vhf Radio Usb...
Baofeng UV5 RA WILL NOT TRANSMIT IN 146 MHZ or 440 mhz bands
It's not programmed right. You can probably find more intelligible programming instructions on Google. Their manuals are not great.
Jul 21, 2013 | Radio Communications
Baofen UV5 RA wont transmit
Baofeng manuals are notoriously hard to read/interpret. Check on Google. Several people have created better instructions.
Unable to transmit
The CTCSS codes are probably not set correctly. Baofeng manuals are notoriously hard to read. Look online (Google) alternative programming instructions.
Jun 09, 2013 | Radio Communications
Cannot load program to my uv5ra
ok check whats is the program firmware when you turn of press the number 3 hold annd turn on and you see BF297 or BF291 if are 291 the program is BF_5R IF NOT ARE BAOFENG NEW VIP GOOD LUCK OR GO TO MILKLOR.COM
Apr 03, 2013 | Baofeng UV-5RA Dual Band Transceiver
Sep 13, 2012 | Generic Walkie Talkie BAOFENG BF-888s Two...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
