Question about LG WM2233H Front Load Stacked Washer / Dryer
08006623 Hi, I have Frigidaire Electrolux Washer/Dryer Combo Model #GLET1142CSO and I need door switch for dryer manufacturer # 08006623
onthejob5130
  • 640 Answers
SOURCE: LG washer/dryer combo will not drain water
easy first unplug unit..take back remove phillips head screws...now the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
Posted on Dec 25, 2008
tzweeb
  • 318 Answers
SOURCE: washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
Posted on Dec 28, 2008
  • 7 Answers
SOURCE: LG privilege WD-3243RHD User Manual
Find out where in your area it was sold and phone or ask salesman for Manuel or instructions they will be glad to help.
Posted on Jan 22, 2009
  • 360 Answers
SOURCE: Need to reverse dryer door on Model #FEFB9200ESO
instructions are available here
thanks for using Fix Ya, please take the time to rate this solution.
clarkco
Posted on Feb 06, 2009
MNTECH
  • 1543 Answers
SOURCE: Dryer will not Dry!
A conventional dryer uses 240 volts to heat air, which passes through the tumbling laundry, picking up moisture, which is then vented to the building's exterior.
Your dryer uses 120 volts to warm air, which picks up moisture from the tumbling clothes, which then passes through a vent pipe in the back right corner of the dryer where a cold water spray causes the moisture to condense, run to the drain, and then is pumped out of the washer/dryer combo. There is no exterior vent to the outside of the building. Drying with your dryer will take at least twice as long as with a standard dryer. You can wash large loads, but can only dry small loads, and the clothes will not be as dry when dryer is finished as they will be with a standard dryer.
All that said, to make sure your dryer is performing as well as it can, you might like to take the back cover off and check the elbow at the very left bottom corner (when viewed from behind) to make sure nothing is obstructing the flow of water under the tub to the drain.
Posted on Aug 21, 2009
Frigidaire Washer Dryer Combo (Stacked) We had to have the power shut off to our house. Now that it is turned back on, our washer dryer combo won't start.
Thank you for your inquiry, Caroline!
From the information you have provided your Frigidaire laundry center is no longer working. I understand that you had to shut off power to your house and now your laundry center is not coming on. It sounds like you could have a possible short within your timer. I would recommend performing a reset on your laundry center and you can do that by unplugging the power cord for roughly ten minutes. If you continue to have issues with your dishwasher can you provide me with your model number? In order to locate your model number you can find the serial tag and that should be located on the inside wall of your dishwasher. I look forward to assisting you further. -OOS
Mar 23, 2015 | Koolatron 1.7cuft Thermoelectric Fridge
I have a Frigidaire Gallery W/D set. The model number for the washer is GLWS1339CS1. I need to dryer model # and the sticker is missing. Help?
Hi Joshua, I am happy to assist you!
I understand you are seeking the model number of your Frigidaire dryer because you are in need of the replacement part number of the heating element. Each appliance has its own model number listed in the serial tag on the unit itself. If the serial tag is missing or no longer visible on the upper front as you open the door of your dryer, at this point I would recommend reaching out to the manufacturer to verify if they have any documentation or your product registration. Best regards - Z
Mar 28, 2014 | Frigidaire Washing Machines
Electrolux Dryer Heating Element 131553900 is this the right one for model #fex831cs0 or can you restring the original if so what is that part Number
Hi L Martin - For this particular model FEX831CS0, the heating element part number is 131475320. The part may be purchase directly from the manufacturer or through a part distributor in your area.
Mar 18, 2013 | Frigidaire FEX831CS Top Load Stacked...
Eied55hmb electrolux dryer door adjustment
Good Afternoon Vijay, thank you for your post! From what you have described it sounds like the door strike is not aligning with the door lock or the dryer possibly has a defective door switch. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Dec 31, 2012 | Electrolux EIED55HMB Electric Front Load...
Open ground at dryer outlet
Hi robert_cr334
Go to the following webpage and see that you have the wiring correctly
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Oct 15, 2012 | Frigidaire Dryers
Hello, I have just purchased a frigidaire gallery series stackable combo 2004 model glet1142cso after hooking it up i am having problems. It won't fill unless dryer door is open..won't spin out...
Probably an auto tec installed the recepticle on the wall or in the electric pannel. in home electric the black wire and the red wires are hot. In automobiles the black is ground. You should have 240 volts between the two flat connectors on the plug when its pluged into the recepticle.
Dec 20, 2017 | Frigidaire FEX831F Top Load Stacked Washer...
LG WM2233H Front Load Stacked Washer / Dryer Logo
74 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
