Question about Garden
Husqvarna 51 specs - Garden
Where to find vent line on 359 husqvarna
Husqvarna chainsaw fuel line check and replace - YouTube
? 3:44
https://www.youtube.com/watch?v=8FyU_fG9qwc
Feb 6, 2012 - Uploaded by mweba1
359. ... Husqvarna chainsaw fuel line check and replace. mweba1. SubscribeSubscribed .... You will want to inspect the tank vent and fuel line.
Husqvarna common air leak - YouTube
? 1:51
https://www.youtube.com/watch?v=Z7f9zNQTJBQ
Apr 11, 2012 - Uploaded by mweba1
Husqvarna common air leak ... Husqvarna 136 ChainsawCarburetor Rebuild & Fuel Line Repair - Duration: 22:39. by donyboy73 59,377 views.
Husqvarna 359 Professional Chain Saw Review
Dec 14, 2015 | Husqvarna Garden
Husqvarna problems
If spark is ok then I would say the carburetor is the likely problem or the fuel is not entering the engine. Something like the following instructions might help.
How to Adjust Husqvarna Carburetor eHow
Look at this manual for model 51 carburetor adjustments.
http://www.getsaws.com/PDFs/w9600001.pdf
Aug 06, 2014 | Husqvarna Chain Saw Models 51, 55
Husqvarna 51 file size
Several bar and chain combinations fit the 51 model saw. If your saw runs an H46 / H80 or H81 style chain you will need a 7/32" (5.5 mm)
If you are running a H21 style chain you will need 3/16" (4.8mm)
May 02, 2014 | Husqvarna Chain Saw Models 51, 55
How do I adjust the air gap on the ignition coil
The best way is with an air gap tool. Most Husqvarna saws run a 0.3 mm or .012" air gap.
May 01, 2014 | Husqvarna Ignition Coil 55 257 245 51 254...
How to adjust oil flow to bar on husqvarna 51 saw
The 51 does not have an adjustable oil pump.
Feb 16, 2014 | Husqvarna Chain Saw 20" Bar
45 coil setting
The air gap between the unit and the flywheel should be 0.3mm for the Husqvarna 45
Oct 16, 2012 | Husqvarna Ignition Coil 55 257 245 51 254...
Husqvarna 45 coil setting
Slide a 0.25 feeler guage between the flywheel and the ignition module.
Oct 15, 2012 | Husqvarna Ignition Coil 55 257 245 51 254...
The Husqvarna chain saw models 51 and 55 does not starts.
Is this about two different chainsaws? You will need two different posts giving the particulars about each saw.
Sep 15, 2012 | Husqvarna Chain Saw Models 51, 55
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
