Question about Garden
Husqvarna 51 speed linkage
Can't reassemble linkage to carburetor.
  • 1,807 Answers
I assume you are refering to the throttle linkage. Do you have the breakdown manual.? If not here it is -
Posted on Jul 22, 2013
How do you put the throttle linkage on to the carburetor on a model 51 w/zama carburetor?
Husqvarna 51 55 zama Chainsaw Carburetor
if like most carbsy connected before fitting
looks like only one hole for a wire or throttle cable
Nov 02, 2016 | Garden
Starts but stalls when hot. Chain is not too tight
Larry,Carburetor may be dirty, remove and clean or rebuild. Check the attached links,videos,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna Chainsaw 235Troubleshooting Repair Help
How to Troubleshoot Husqvarna Chainsaw Problems eHow
Husqvarna 136 Chainsaw Carburetor Rebuild Fuel Line Repair
http://www.mymowerparts.com/pdf/Husqvarna-Service-Repair-Manuals/W9200002.pdf
Apr 19, 2016 | Husqvarna Chain Saw Models 51, 55
Husqvarna problems
If spark is ok then I would say the carburetor is the likely problem or the fuel is not entering the engine. Something like the following instructions might help.
How to Adjust Husqvarna Carburetor eHow
Look at this manual for model 51 carburetor adjustments.
http://www.getsaws.com/PDFs/w9600001.pdf
Aug 06, 2014 | Husqvarna Chain Saw Models 51, 55
How to remove carb on 350 husqvarna chain saw
Remove the air box cover and remove the air filter. You will see 2 screws going into the carburetor. These 2 screws hold the carburetor onto the saw. You must use care (and take a couple pictures) to see how the linkage fits back onto the carburetor. You will also see the choke and kill button on the left hand side. Take you time and you should be fine. The throttle linkage is the hard part.
Jul 08, 2014 | Husqvarna Garden
My husqvarna 51 will not idle after cylinder replacement
Did it receive a new piston and rings at the same time? Is the carburetor firmly mounted to the cylinder? Check for muffler plugging. Did you make any adjustments to the carburetor jets? Try turning the idle-speed-screw CW a turn or two. Are you running fresh fuel mix? If the ignition module was removed, set the pole gap with a thin business card and have the magnets under the pole pieces. Hope some of this helps!
Apr 09, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna 51 chainsaw wil start up and run as long as I keep givig it gas but as soon as I let go of the trigger it dies. I tried turning the idle up but it does not make a difference. It was very recently...
First, check the fuel lines for cracks/breaks.
If they are o.k.,then you will need to disassemble the carburetor again and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Usea Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 13, 2009 | Husqvarna Garden
Husqvarna 51 chainsaw will barely run, magnito and carberator ok
Probably need to re-adjust the carburetor jets. They are very small screws in the base of the carburetor. They will be labeled with an "H" and an "L" . Set the low speed first by turning it in slowly until the rpm drops slightly then start turning it outward untill the engine idles smoothly. At that point you can also adjust idle speed. Then you need to be careful here but you need to hold the throttle wide open at the same time adjusting the high speed jet. Turn it in until the rpm drops then slowly turn it out. The rpm will keep increasing. Once you get to a point where it is max'ed out then screw the jet back in one half a turn. Changes in altitude like using your chainsaw in town versus going to the mountains for firewood can sometimes make it necessary to adjust the fuel/air ratio.
Feb 18, 2009 | Husqvarna Husky 165
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
