Admin and Passwords come as default. If you changed it and forgot, try unplugging the DVR and restarting. You can also still open the settings and try to re- factory the DVR if the settings permit. Next, I have to assume that you got the Booklet or the email or URL addresses to download same.
There is in the hand book the default password as the User name:password and the Password #'s 1-6. Good luck.
You need to provide us with more info. Your dvr broadcasts on an iPhone address with a port number. Both of these are needed. Then the bbrand of router you have is also needed
To check the IP address, press MENU key on the unit and enter password to access OSD setup menu. Select <System Setup>, <Network Setup>, then <LAN Setup> to check the IP.
Hi, I have a 4 CH H 264 DVR monitor for my 4 cameras in the shop, I have forgotten my password, can anybody help me to unlock the system and either rcover the password or put in a new one.Many thanks. Giuseppe
add camera to the router that is allow it in the setup. the devices will need to be allow either by MAC address or device name. check your user manual for correct setup procedure. usually found on the CD that came with the router.
