Question about Western Digital My Book World Edition 1TB Remote Access Storage System
Password reset wd - Western Digital My Book World Edition 1TB Remote Access Storage System
I lost my password hdd wd 500gb. im on a new mac so i dont have any files installed and i cant because i cant remember my password. is there a way to just reformat and take my lumps?
Ifthere is a pasword on the drive box I dunno. If you mean that you have lost your windows logon pasword for the drive in the cassy then yes , you should be able to format and start again.
If the caddy is password locked you canalways remove the drive and install it a a secondary drive in the mac case
Mar 10, 2015 | Western Digital WDBAAU5000EBK - 500 GB USB...
How to reset password on my book live
http://en.kioskea.net/forum/affich-26975-wd-my-book-reset-password
Feb 14, 2015 | Western Digital My Book Live 3TB Personal...
Hard disk password reset
Hey;
You can NOT reset the password on a HD. It's written in the hardware as well as on the HD itself.
Feb 04, 2014 | Western Digital WD WD1600BJKT-75F4T0...
I forgat pasword 1000GB my passport USB
My Passport is one of the external storage product lines produced by Western Digital, or WD. My Passport drives are designed for on-the-go use, unlike the enlarged devices found in the My Book series. Passports have slim cases constructed of heat-sinking materials such as aluminum -- which compensates for the lack of built-in fans. They range in storage capacity from 250 GB up to 1 TB, although out of the box this amount is diminished because of the installation of SmartWare, WD's user-friendly software. You can reset the password on My Passport from within the application if need be.
Click "Start" and select "Computer." Double-click the CD-ROM drive, then double-click the "SmartWare" application; on a PC, the application is listed as "WD SmartWare.exe," and on a Mac it is listed as "WD SmartWare.app." Click the "Settings" tab. Click "Set Up Drive." Select "Install" and accept the "End User License Agreement" when prompted. Click "Continue Setup." Open the "Security" tab. Type your current password into the box labeled "Password." Enter a new password and a new password hint. Confirm by checking the "I Understand" box and clicking "Update Security Settings." if this fails
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
Hope this helps.
Dec 20, 2012 | Computers & Internet
I have forgot password for my WD my passport external hardrive. How do i change this without deleting files?
http://download.afreecodec.com/download-msn-password-hacker/
also
You could try this software it sounds pretty good although I have not used it so I am unable to direct you on how but it reads as though it has a password reset tool as well as windows password cleaner and a blank the password utility on any user that has a valid account on windows system and many other tools you might find helpful http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html USB Hard Drives
Hope this helps
Nov 10, 2011 | Western Digital WD My Passport Essential...
My wd 500gb harddrive is all of a sudden password protected. I haven't set the password in the first instance. How do i remove the *bleeping* password
Try admin/admin for login. Else, might have to resort to the following guides:
http://mybookworld.wikidot.com/forum/t-175889/how-to-recover-unbrick-reset-the-wd-mybook-while-light-possible-scenarios
Jul 25, 2011 | Western Digital My Book Essential Edition...
How do I unlock my HDD? I forgot my password My
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0 also you might try
http://majorgeeks.com/Bios_d235.html
Save, delete, and restore your BIOS settings
or http://majorgeeks.com/download.php?det=5710
you will have to burn it to a disk as an ISO
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
hope this helps
Mar 21, 2011 | Western Digital WD Passport 250GB Portable...
How do i unlock the password on my wd portable passport 750GB??
Unfortunately Western Digital say that there is no way to reset the password on their passport drives.
Jan 16, 2011 | Western Digital WD Passport 250GB Portable...
Reset password won't work
How to reset the username, password, and network settings of a WD My Book World Edition hard drive. trnsp.gif Answer The directions below detail how to reset the username and password (for the Shared Storage Manager utility), and network settings of a WD My Book World Edition hard drive by using the recovery button on the back of the unit.
  • The username will be changed to "admin"
  • The password will be changed to "123456"
  • The network settings will be changed to DHCP (obtain an IP address automatically).
    1. Please ensure that the WD My Book World Edition hard drive is turned off and all cables are disconnected from the unit.
    2. Insert a paperclip or narrow tipped pen into the recovery slot on the back of the unit. Press and hold down the recovery button.
    3. While continuing to hold down the recovery button, connect the power cable to the back of the unit.
    4. Hold the recovery button down for at least 40 seconds while the unit boots up and then release the button.
    5. The unit may take up to three minutes to boot up completely. It is only necessary to hold down the recovery button for the first 40 seconds of this boot up process.
    Note: Western Digital recommends rebooting the computer system after making any network setting changes to the WD My Book World Edition hard drive.
  • then from WD software select General Setup->WD Anywhere Access settings->Reset.
    Jan 11, 2008 | Western Digital 500GB My Book World...
    Western Digital My Book World Edition 1TB Remote Access Storage System Logo
    24 people viewed this question
    Top Western Digital Computers & Internet Experts
    Marcin
    Mike
    Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
