Question about AMD K7 , 800Mhz (amdk7800mpr24b)
Is my main board defective??
Recently i had an odl pc at hme,a pentium 2.. 1 tried a lot of graphics cards and it really worked well.. But someday before a frien sold a pentium 3 with me.. iits really good but when i put the graphics cards in it,my monitor does not display anything.. like mu monitor is not plugged.. but i checked all graphics cads..only one hardly works.. why is it so?? its a creative 16mb graphics card.. i tried S3 trio 3D/2X... 4mb i tried S3 savage4...32mb i tried creative 8mb i even tried S3 trio 1mb.. But the same prob.. i dont know why is this so... someone please help me.. i am really scared if i buy another ge-force and i cant use it on my pc..
    Master:
  • AMD Master
  • 752 Answers
You should download and install the correct drivers for your video card as well. They should work with basic functionality anyway. As Stan says check the AGP is enabled in your BIOS not only the on-board graphics (on my PC I have two options for this, "OnBoard/AGP" or "PCI" so this doesn't arise)
There are many guides to install a new / different graphics card in your computer eg there's one here http://www.playtool.com/pages/vidtable/table.html
10.December.2014
Posted on Dec 10, 2014
    Novelist:
  • 231 Answers
Hi, The problem sounds to me like you need to access the bios and make sure the AGP is enabled. If this is enabled then you may need to go to the manufacturers site and download the drivers for your board and operating system. With a P3 you should have no trouble running XP so if you are not using this already then perhaps you need to upgrade as XP has a very good set of drivers built in and will run most video cards and sound cards Regards mistyman
Posted on Aug 29, 2007
SOURCE:
It will not work i switch it on and nothing happens
Remove cable connecting monitor to computer, turn it on. If you see a "NO SIGNAL" note, your monitor is ok and the problem is the graphic card of your computer. If you've recently removed and reconnected the monitor, might be a bent pin of cable input.
If Monitor is dead when you turn it on disconnected, it's defective and you should repair it
Apr 26, 2015 | Computers & Internet
ATI RADEON 9000 not recognized on GA-686bx board
ati is not compatable with the new intell boards get a NVidia card for intell boards.
Feb 22, 2014 | ATI RADEON X1650 Graphic Card
Intel Vga For windows 764 bit
That board doesn't have integrated graphics and requires a PCIe express graphics card that comes with the drivers.
Just like these you see here on AMAZON, they are standard and work with any main board.. I'm just showing you these as examples... http://www.amazon.com/Graphics-Cards-Computer-Add-Ons-Computers/b?ie=UTF8&node=284822 you can pick any up from your local shop.
Dec 29, 2012 | Intel PENTIUM DUAL CORE-E5700-3.0...
Which is the best graphic card for intel DG41RQ mother board
I have a motherboard intel dg41rq and intel core 2 duo E7200 and nvidia geforce 9500 GT and 4gb ram (DDR3).It will work with call of duty black ops 2 and FIFA 13.So your done.
Oct 02, 2012 | Intel DG41RQ Motherboard CPU Bundle - ...
Does my pc that is intel pentium dual core e2140 @1.60ghz have pci express?? Can this processor support graphic cards like nvidea 9500gt 1 gb??? or any other cards???? plse reply fast
Graphics support is mainly determine by the mother board. based on the processor you have that mother board should be equipped with a PCI express slot. in that case YES it is Supported. make shure you follow installation instructions and check that you have at least the minimum power supply requirements for the card 380W or above.
Best of luck
Jun 01, 2011 | Intel Pentium Dual Core E2140 / 1.6 GHz...
When i run any game it shows fatal error or shows a message unable to initialize graphics pleas tell me what to do
It sounds like either graphic driver or fault card. You may want to look into reinstalling the drivers, if that fails you may need a new video card.
Mar 01, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Recently, when I play graphics intensive games like devil may cry 4, or resident evil 4, the screen suddenly turns black(and becomes unresponsive(need to manually restart the pc)) or it show the blue...
Hello.
Looking at your specs, I assume that a Pentium 4 is not enough to run these kinds of games, so the overwhelming amount of data going through the cpu may have been causing your system to overheat.
Do these steps:
(1) Uninstall and then re-install your graphics card driver, if problem persists, go to number 2
(2) Try playing around with the ATI Catalyst settings, set everything there to default
(3) If problem still persists, then I -am- sure that your PC and/or graphics card is way too overheated, in this case:
(a) I recommend getting a heat-monitor (doesn't come cheap though) for your PC, to keep yourself notified of the temperatures of your PC
(b) Try buying more fans and if you can afford it get a water-cooling system
Above all, if you can afford a better -Gaming- PC then I'd suggest that, because your system isn't really that great for new games.
Nov 23, 2010 | ATI RADEON X1650 Graphic Card
Which specific harddrive components would you put into a home-assembled PC?
DUE you're going to work with graphics files you need a good HDD (capacity) 500 GB will be great
Memory at least 1GB and above
Processor 3.0 Ghhz and above
DVD Drive (any double layer)
Sound card (on board is enough), however you can improve later adding a new one, but you don't need that)
Good Graphics card (At least 256 MB)
Oct 07, 2008 | Computers & Internet
New graphics card needed
If your looking for a fast graphics card u will be limited to mostly 256 mb nvidia chipsets.
lots to choose from. go to www.tigerdirect.com
Oct 05, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
Open Questions:
AOL MAil SuPPoRt USA $%&^*!{1^855^536^5666}#[email protected] PHoNe NuMbER MARYLAND This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I855%536%5666 is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 16, 2019 | AOL Computers & Internet
AOL MAil CuStOMeR Care {1^/855~/536~/5666-} VIRGINIA This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I855%536%5666 is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
See all AMD K7 , 800Mhz (amdk7800mpr24b) Questions
AMD K7 , 800Mhz (amdk7800mpr24b) Logo
154 people viewed this question
Top AMD Computers & Internet Experts
Ekse
Alun Cox
Carlo Barzo
Carlo Barzo
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
