EPSON STYLUS CX5800F power won't come on when power button is pressed. Was ok up till yesterday. Saw light go out by its self. Then wouldn't come back on. Later on it was ok. Tried using it today and power won't come on. I don't see a reset button or anything either.
Turn on the printer, press the cancel button (upside down triangle inside a circle symbol), now press the Setup button (spanner symbol). Press the up/down arrows (or number 5) until you see "5.replace cartridge". Now press OK, the carriage will move to the replacement position.
Turn the printer on, when time is displayed press the setup button. Press the up/down arrow buttons to get to "5. replace Cartridge" and then press OK. Open the scanner unit and lift the lid off the ink carriage unit. Remove the empty cartridge and fit the new one. Make sure the cartridge and carriage cover click down into place, close scanner unit and press OK. The user guide with pictures can be downloaded fro Epson here: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=58607&prodoid=58654753
Please take a moment to rate this solution, thanks.
Check for obstructions (ie tiny pieces of paper and other foreign objects)
Clear the obstructions.
press the paper button
Turn it off then do the self test and check if the printer will printer without using computer
self test (press and hold the paper button and press and release the power button, if you can see the green light is flashing release your hold on the paper button. By the way make sure there is paper on the printer)
If it prints good then you need to check the settings on your computer.
I had that same problem with my CX5800F. I tried it in several working outlets and shut down/started up many times. Tech support couldn't figure it out so they had me sent it back for a replacement. Several days later, before I packaged it up for shipment, I decided to test it out one more time, and it powered on! I sent for a replacement anyways. Since it's still under the 1-warranty, I'd suggest sending it back for a new one if all else fails. Good luck!
The scanner cover is on one set of hinges. Below the scanner bed, you can lift the front edge and the scanner bed will lift up on another set of hinges. Do not attempt to manually position the ink cartridge holder to replace individual cartridges, but follow the instructions from the print dialogue box, under Epson Printer Utility and Epson StatusMonitor.
with the printer on press & hold both the small red button ( far right ) and the green, colour copy button. Whilst still holding press the power button wait till the unit powers off. Press the power button again, shortly after the unit powers on, the lights flash, let go of the two buttons your holding. The screen shoul dnow say "Init EEPROM" if it doesn't repeat procedure till it does. Now press the green colour copy button once, screen should now say "Push power sw" Press and hold the power button, the unit will power off and on again, now release the power button and your printer should be working again. Now you should change your waste pads......
