Digihome freeview recorder problems
My digihome 320sd keeps turning itself off and back on for no reason
5 Suggested Answers
SOURCE: Thomson 80gb freeview recorder box (Top up tv model) UK
have you connected the small cable at the back?
Posted on Mar 04, 2009
SOURCE: user manual digihome dtr80
There are two versions of the digihome dtr80 which are made by Vestel. If you look underneath at the product sticker you will find one of three numbers:
T810 : In this case youve been conned into buying a digihome pvr80. This has very limited functions and cannot series link.
T816 : This does support series link but you need to install new firmware using a computer a a serial extension cable. You can get the firmware from here: http://www.futaura.co.uk/vestel.html You want version 6.8. Bear in mind there areside affects to this program such as recording every episode that comes along on that channel and a very sluggish interface.
T825 : This does support series link by default. You go to the epg, highlight the program you want to record, Press the OK button and a menu will appear. Select series link.
Please be aware series link only stays active for 13 weeks so you will have to redo it halfway though a series.
Posted on Jun 29, 2009
SOURCE: Hi guys i bought a Digihome DG250DTRA08 freeview
Did you get one ? - if not I will copy and send.
jrb
Posted on Apr 07, 2010
  • 212 Answers
SOURCE: how to tune freeview for digihome PVR80
On your remote control, press 'menu'.
Then select 'set up' on the screen.
Then select 'Installation' on the screen.
Then select 'Automatic channel scan' on the screen.
The box should then scan for all channels, and with luck BBC will be included. If not, please repost. Some older Digihome PVR80s can't cope with the new multiplexing standard employed by digital freeview.
Posted on May 07, 2010
I have a 22" digihome LCD TV with built in DVD. At 3am every morning the DVD activates and buzzes away. The screen doesn't come on but there is a loud click as the speakers activate. How can I stop this...
3am is the freeview box update time it will do this every day at 3am the loud click you hear you should not hear it but it may be the update switch that turns the tv out of standby for the freeview to be updated its a different switch that turn this on and may be sticking.
Oct 02, 2013 | Digihome LCD TV
check all conections try retuning ect
Sep 10, 2013 | Televison & Video
I have a new Digihome 24 inch Freeview TV. Unable to get any channels? any ideas??
have the wires right in the back of the TV, or unplug everything and start over from the get go.
Dec 30, 2012 | Digihome LCD TV
I have just bought a Digihome pvr320sd tv recorder with freeview, can i set it up as a tv recorder only without the freeview as i already have built in freeview on my tv.
When you set up the recorder Freeview stations will be stored. This means that you can record TV stations without watching them. So you can say watch BBC1 on your TV and record a program on Channel Four. You need the recorder set up with Freeview to recorder channels. Otherwise you would have to have your TV on and recorder set to record via the scart lead. Which would be not great quality and messy.
You should be able to loop the aerial lead so that both the TV and recorder can get the signals from your aerial, if that's what is bothering you.
Dec 22, 2012 | Televison & Video
No instruction to set up the freeview box digihome dvb 915 can you help
Set up should be quite straightforward assuming you have all the bits.
You will need
  1. a standard co-axial aerial lead from your TV antenna to the female socket on the Freeview Box
  2. A scart to scart lead to connect the Freeview box (tv out socket) to the television.
If you wish to connect a video recorder or other equipment you may also need a second coaxial lead (male to female) for the RF through socket to connect to the aerial in socket on the video recorder.
If your TV does not have a scart socket you can connect the scart lead to the scart socket on a video recorder and then use the normal method of watching videos to view the Freeview TV pictures (here you may need to press the PAUSE button on your video recorder to prevent it going back into standby-mode after a few minutes).
Simply connect the box to your TV, turn on the power and the auto channel-scan will immediately detect and install all available channels.
If the Freeview box has been previously used in a different location / with a different TV transmitter you may need to re-tune it. Press the menu button on the remote control, scroll through the menu to set-up. Follow on screen prompts.
Feb 09, 2011 | Televison & Video
How to tune freeview for digihome PVR80 it wont record bbc how to fine tune it .when we had to re-tune for channel 5 it worked perfect so please tell me how to do that again
May 07, 2010 | Televison & Video
I have a Digihome DV940B freeview receiver, and wish to set it up with a tv and video how and where do I put the areal and scart leads
This depends on how you want to use your kit, and how many scart plugs you have in your TV and VCR.
If you have 2 scarts in your tv;
Aerial coax goes to digihome aerial in. Aerial out from digihome to aerial in of vcr. Tune vcr into Digihome.
Scart plug from digihome to tv.
Scart plug from vcr to tv.
You can then record what you have selected on your digihome box.
In my humble opinion, it's worth splashing out on a pvr; you have more functionality such as being able to record 1 program and watch another.
Regards
Zahc
May 05, 2010 | Televison & Video
User manual digihome dtr80
Jun 06, 2009 | Digi Televison & Video
Jun 04, 2008 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
