Question about Haier CPRB09XC7 Portable Air Conditioner
Manual how do you empty the water
Ice maker not working.
If your water tray was empty check the water supply to the fridge .
you shouldn't fill it manually.
\if the water supply is turned on, then the operating solenoid that allows water into the tray is faulty.
Whoever repaired your fridge should be called back immediately.
Dec 02, 2014 | Refrigerators
How do I clean my humidifier Holmes hm 500? I don't have the manual anymore. Thank you! Jaimee Murphy
If you are trying to descale it of all the mineral build up. The easiest way is to mix a 50/50 1 gallon solution of Distilled White Vinegar and Bottled Distilled Water and pour it in the empty tank. Allow it to sit for a couple of hours (Longer if it's really scaled) . Then turn it ON and run it, until the tank is half empty. Then empty the remaining solution and fill the tank with Bottled Distilled Water and run until it's empty. In the future, it's better to use Bottled Distilled Water, rather than tap water.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Holmes Products HM500-UC 1 Gallon...
My water softener emptied im not sure how long it was empty for but I dont think it was too long I filled it with salt and now it doesnt work. It still regenerates but im getting hard water still any...
Do you mean the salt tank was empty? If so fill salt tank half way wait about 6 hrs for brine to develop. Manually regenerate softener 2x within 24 hrs. When the salt runs out the resin becomes saturated with hardness minerals. It takes at least 2 regeneration cycles back to back to completely restore soft water. Also the hot water will take some time to get soft. It will help to flush water heater after cold water is consistently soft.
I hope this helps,
h2oservices
Feb 26, 2011 | Culligan Compatible S7011C RS23SED5...
I tryt to turn on my humidifier tonight.1st the mist was coming out just little bi,but there was no green light on,like the manual sed and the humidifier was making some wird noises too.
Welcome to Fixya!
  • Ensure that the water tank cap is secured properly to water tank.
  •  Empty out water in water basin. Place filled water tank on to empty water basin.
  •  Clean Water Level Sensor.
Hope this helps!
Oct 26, 2010 | Crane Elephant EE-3186 1 Gallon Humidifier
Washer won't drain.
hi, to empty water manualy, lift the hose from the stand pipe, keep it above the water level, place a bowl on the floor and lower the hose into it, the water should drain out, to stop the water flow lift the hose above the drum and empty bowl, continue until empty, hope this help, thanks for using fixya
Feb 14, 2009 | GE WBSR3140DW Top Load Washer
How do i empty the tank
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, fe shows in the display how do you empty the tank.
This is the user manual site.
scroll down to the diagram on page 16 and they describe how to empty the water from the system
http://www.delonghiusa.com/manuals/PACL90.pdf
To empty the tank on the rear of the
appliance.
Pull out the 2 drain hoses, take off the caps
and let all the water flow out
When all the water has been drained, place
the caps back on the hoses and put the
hoses back inside.
Clean the filters and dry thoroughly before
putting them back.
Remember to give me a solved rating before you log off!
Thank You Huuum
Aug 12, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
HOW MUCH WATER CAN THE 7000 BTU HOLD. I USUALLY PUT A RUBBER MATERIAL WHERE THE WATER LEAKS FROM SO I WONT HAVE TO PUT A BUCKET UNDERNEATH. HOW LONG CAN I LEAVE IT LIKE THAT FOR BEFORE EMPTYING OUT THE...
Hi, Go to the following website and download the manual. According to the manual, the unit "evaporates" the water and you don't have to empty anything. http://www.haieramerica.com/en/asset/product/96d890cdae
May 25, 2007 | Haier 7000 BTU Portable Air Conditioner
Haier CPRB09XC7 Portable Air Conditioner Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
