Question about Hotpoint RGB745 Gas Kitchen Range
Samsung RGSF5330DT Range dead.
Digital control panel went blank (for oven), and oven does not heat. Gas is on. Burners & oven light are working O.K. Is it possible there is a fuse (or is the control panel bad)?
  • Anonymous Mar 16, 2014
    key pad is blank, oven will not heat but the burners do work.
  • 63 Answers
Try checking control panel connections they might be dirty if not then board is proberly bad
Posted on Aug 29, 2007
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
GE gas range JGBP33WEH3WW totally dead after self clean
There may be an oven over temp thermal switch that has opened and needs to be replaced. Also you need to determine why the temp got so hot to cause this safety device to do its job. This might be a failed cooling fan
Nov 17, 2013 | GE JGBP33 Gas Kitchen Range
Oven won heat unless burner is on
Check the oven ignitor, it may be bad. See if you have power going to the ignitor.
Oct 23, 2013 | Samsung RGSF5330DT Gas Kitchen Range
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
My house got hit by lightning, the control panel went blank burners work but not oven
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Aug 30, 2010 | Whirlpool RF380LXPS Electric Kitchen Range
Oven won't light
if you can use a tester to check both sides of the double breaker (i assume this is 220v ) see if there both powered...sounds like you lost one side of the 220
Jun 15, 2009 | Ovens
Oven Temp Display
if the oven doesnt work and the display is blank then you would have to get a control board for the unit.
Jan 22, 2007 | Samsung RGSF5330DT Gas Kitchen Range
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Hotpoint RGB745 Gas Kitchen Range Logo
224 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
