Question about Ovens
Maytag precision touch control 800
The oven light on my Maytag Precision Touch Control 800 Electric Slide In won't go on. I removed bits of the burned contact tip from the bulb that burned out and, in the process, noticed what looked like arc burns across the pos/neg terminals in the socket. Is there a fuse panel anywhere on this model?
How to remove oven door maytag gas precision touch control 700
most oven doors can be removed by opening the door until its about 1/4 open, or when it will stay open part way. when the door is in this position you should be able to just lift it off the hinges straight up. make sure you dont accidently push the "arms" of the door back in, as they are spring loaded and are hard to get back out, especially when the dorrs is removed. When done just slide back on the way you took it off.
Jul 20, 2014 | Maytag Ovens
Oven will not turn on after self cleaning has finished
If electric turn the oven to bake and look at the bottom element. If if does not turn red hot, it may be defective.
If gas, turn to bake and watch the igniter to see if it get red hot. If not, it may be defective.
May 22, 2014 | Ovens
How do remove the oven bulb cover in a maytag precision touch control 800?
the trick is to push the metal ring IN at the same time as turning the bulb cover counter clockwise
Feb 01, 2013 | Ovens
We have a maytag oven. all the buttons work except for the bake and light button.Mod # umc5200aaw
only half of one side of the maytag oven touchpad control panel works, its one 2 yrs old help!
Jul 06, 2011 | Maytag 30 in. Electric Single Wall Oven...
Bake button does not work.
if the buttons are the touch pads then your control has failed and you will have to replace it .mm
Jul 14, 2010 | Maytag 30 in. Electric Single Wall Oven...
My maytag oven has a function error. F5 and F3
Hi sorianocynth,
Maytag error F5 and F3 do have different indications. Error F5 means watchdog and hardware conflict. The only way to resolve this is to replace clock (ERC). On the other hnd, F3 means you have shorted or open oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. When they send out the part detailed instruction will be provided.
Hope this helps.
Thank you for using FixYa.
Jan 19, 2010 | Maytag 30 in. Electric Single Wall Oven...
I have a Maytag Gase Double Oven Range Precision Touch 750 Series and having a problem with temperature control for lower over how can I fix. Jim
Hello Jim,
Can you clarify the problem you're having, or how the temperature control issue manifest's itself, i.e. can't set temp in display, too hot, too cool, won't ignite etc.
Just some clarity to move you further, hope I can assist further.
thank you
Oct 27, 2009 | Ovens
Ovens Logo
32 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
