Question about Konica Minolta Office Equipment & Supplies
Mfp ip address of bizhub 211 - Konica Minolta Office Equipment & Supplies
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
SOURCE: getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
Posted on Mar 23, 2008
  • 45 Answers
SOURCE: BizHub won't send scans to Macs
first, int the mac must have the "share for windows" checked, in the network settings.
second, you'll have to create a folder name SCAN into the 'home' folder onto your mac. then , you ll have to have your user and password of your mac.
then, you ll have to enter in the bizhub:
- Ip of your mac
- gateway of your mac
- mask of your network
on the copier
- in the utiliy/counter // register 1 touch, book adress, SMB (don t remeber exactly the path .. but just not so far of these paths), :
IP server: Ip mac
path : SCAN
user: user'sMAC
password: password of the user's mac (CAN NOT BE EMPTY)
and ormally, that's all folks :-)
Posted on Jan 10, 2009
  • 88 Answers
SOURCE: printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
Posted on May 23, 2009
xeerie
  • 347 Answers
SOURCE: how to solve bizhub 211 code error c0650
bizhub 211 error code C0F32, To solve this code simply replace the developer of the machine.
Posted on Jun 18, 2010
Bizhub C450 strange printing problem. Green data LED is flashing but nothing happens.
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Nov 15, 2014 | Konica Minolta bizhub C450P Laser Printer
Reset password bizhub 211
how can i reset the password for my konica minolta bizhub 211 to remove the maintainance call 2 display?
Nov 21, 2012 | Konica Minolta KONICA BRAND TN-211 BLACK...
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub 350
You are getting a failure sheet. This happens when the scan doesnt go through. I think you are reffering to SMB scanning, which needs to have the following setup on both the MFP and the copier.
Host ID or NAME - IP address or hostname with DNS resolution.
Share Name - This is your SMB share name or folder share name on the remote PC
User Name - This is an account that is configured on the remote PC
Password - This is the password for the account setup on the remote PC.
Some things to keep in mind: Third party firewalls can block the bizhub from writing files.
Set share permissions to full control. (under sharing tab> permissions buttion)
Set NTFS permissions to at least write access. (if you have a "security" tab on the shared folder.
Or, you may see something like "allow network users to change my files" on the sharing tab. This basically does the same under different configuration scenario.
One last thing. If you havent changed anything since the problem started, it is probably just something like an expired password on the account that is setup for the copier.
Good Luck.
Jun 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Scanner - adding new email address onto the system
Go to your web browser and type the IP address of the MFP.
There you will see a tab along the top where, when clicked will let you enter address into the address book.
The MFP MUST have the email set up first, just like a computer as far as domain servers and it also needs a valid email address to log on and send off the messages.
This can be done on the panel of the MFP or by logging out and then back in as the admin through the web browser again.
Oct 22, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Weird scan problem with Konica Minolta Bizhub C351
It sounds like you have setup a fax forward box.
You need to set up a one touch, scan to SMB.
this can be easily done via your web browser by typing in the IP address of the MFP and set it from there.
You need the IP address of the laptop and is best to put the shared folder in the main drive (C).
Then for the file path you just need to enter the name of the shared folder EXACTLY as it is on the lap top.
You also MUST enter the ID a password to give it access.
Oct 14, 2008 | Konica Minolta bizhub C351 All-In-One...
Not receiving faxes
R18 means that your memory is full. Very strange. Go into the user box, file document, system user box, memory rx to delete all of the old faxes. This worked for me.
Aug 07, 2008 | Konica Minolta bizhub C250 All-In-One...
Bizhub c450 - setting account tracking for color only
Yes.
When setting up this option it is one of the variables that can be changed.
I reccomend using the Webportal.
Type the IP address of the MFP and then when the page is displayed, click log out and then log back in as administrator.
You will see the account tract and authification settings there.
This is far easier than navigating through the panel.
Jul 15, 2008 | Konica Minolta bizhub C450P Laser Printer
I cant install konica Minolta bizhub C351 on my mac. please HELP
To print via IP on MAC  type IP address in queue type print ,name the printer and  the correct driver/ fy...35/
Mar 13, 2008 | Konica Minolta bizhub C351 All-In-One...
Can't Network Print
in printer you should log in as administrator and there should be network settings, where you can put in ip address and gatway and so on.
Nov 22, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
268 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
