Ecs mcp73tm3 supported processors - Computers & Internet
I need sound driver for g41tm motherboard
ECS G41T-M v2.0 motherboard supports Intel Core 2 Quad processors, and supports FSB up to 1333MHz
G41T-M features Intel G41 and ICH7 chipsets, by supporting Intel 45nm processors and Core 2 Quad processors, which provides impressive performance. Additionally, G41T-M is equipped 2 DIMM DDR2 800 up to 8GB
get sound (and more) drivers here :
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=925&CategoryID=1&DetailName=Feature&MenuID=16&LanID=9
Jan 10, 2013 | EliteGroup G41T-M6 Motherboard
THIS MAINBOARD SUPPORT THIS PROSESSOR Phenom II X4 920 (2.8GHz, 125W, 2MB total dedicated L2 cache, 6MB L3
Motherboard,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=943&DetailName=Feature&MenuID=1&LanID=0
Processor Support (CPU Support),
AMD Phenom II X4 model 920, uses .0875 to 1.425 Volts, (DC),
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#.22Deneb.22_.28C2.2FC3.2C_45_nm.2C_Quad-core.29
That is the average voltage range for the AMD Phenom II X 4 processor.
Look back at the AMD Phenom chart again on Wikipedia, and look especially at the voltage range for the 900e to the 945.
Now look at the ECS CPU Support page again, and you'll see your motherboard supports Phenom II X4 processors from 900e to 945.
Since the 910e and the 925 are supported, I know the technology of the 920 is supported.
The Core architecture and nanometer technology it is based on, is supported.
No BIOS update may be needed.
Yes is the answer.
For additional questions please post in a Comment.
Regards,
joecoolvette
[NOTE*
That processor can use up to 125 watts of power. You need a decent Power Supply.
That processor also gets H-O-T!
Make sure it has a GOOD cooling system, and the computer case inside, and the Power Supply, inside, are kept clean ]
Aug 04, 2012 | EliteGroup ECS A780GM-M3 AM2+ AMD 780G...
Pm800-m2 rev:1.0
ECS Support > ECS PM800-M2 v1.1 > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=453&CategoryID=1&MenuID=18&LanID=9
1) Features:
2) Specifications:
3) Download:
Drivers, BIOS, and Manuals.
{Note* The second file down is the Motherboard Manual }
4) Frequently Asked Questions (FAQ)
5) CPU (Central Processing Unit. Another term used is Microprocessor, or simply Processor for short)
This page tells you what Processors are supported.
6) Pin-Out
Pin-Out's for the Front audio header, Front USB header, and the Infrared Port.
State the problem in a Comment
Regards,
joecoolvette
Jul 16, 2011 | Computers & Internet
I have an amd athlon x2 3800+ cpu and I can't seem to enable virtualization. My motherboard is an ECS A740GM-M and I can't find the command in the BIOS to enable virtualization. AMD Hypercompatibility...
The CPU itself does not support communication with virtual addresses. the processor wasnt designed to do it. almost everything from 2009 on has the capability minus sempron and celeron processors.
Mar 23, 2011 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Can you tell what are the compatible processor for motherboard p4m800-m v:1.0a
This motherboard supports Intel Pentium 4 processors which are made for socket 478.
If you visit this webpage: http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=453&DetailName=Feature&MenuID=24&LanID=0
And scroll down to the bottom there is a list of the CPUs that it supports.
Hope this helps, please rate my answer :)
Chris
Mar 02, 2011 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Just a follow question regarding ecs 945g-m3 motherboard.. is this compatible for core 2 duo processor with 45nm technology like Intel E7500 (2.93G) 3mb 1066fsb C2D.
According to the ECS website, it should support the 1066 FSB C2D, however it mentioned it's on the 65nm technology. Latest processor support shows for the E6420. So, I doubt it would take the 7500...
Oct 03, 2010 | Computers & Internet
I have an ECS P4M800-M7 motherboard using Celeron D 2.66Ghz processor.What compatible processor can i use for upgrading.
Intel Pentium 4, Celeron D and Pentium D processor FSB 800/533 MHz Support Hyper-Threading Technology Also says Dual Core support See here for information:- http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
Jun 13, 2009 | EliteGroup Intel Pentium 4 Processor...
No processor detecting
Here is the ECS website where you can get the particulars for *********** board to see if it will suppport that processor or not.
http://www.ecs.com.tw/ECSWebSite/Support/Category_Support.aspx?MenuID=3&LanID=9
Dec 23, 2008 | PC Chips (M925G) Motherboard
Computers & Internet Logo
David Payne
David Payne
