Question about Garden
What is the cutting height of a troy bilt 11A-542Q711 at the highest adjustment
2 Suggested Answers
  • 37 Answers
SOURCE: Need to know how to change the oil in my Honda
take out the drain plug under the lawn mower drain it put the plug back fill it with oil then you done
Posted on Jun 06, 2009
Can I put a bigger diameter wheel then factory 8in on the rear of my Troy bilt TB210 self propelled mower ( Front wheel drive)
yes but it will effect the speed. a bigger wheel will make it pull faster. and the deck will have to be adjusted for the right height of the back wheels for cutting grass even
Jun 09, 2018 | Troy Garden
My Troy-bilt lawnmower model number 11A-A2BM711 HAS GAS HAS OIL doesn't start please help its only 3-4 yrs old
You need to pull the spark plug and verify it has spark, my guess is that it has no ignition spark due to a failed igniter unit or pickup coil.
May 03, 2017 | Troy-Bilt Garden
I over tightened the blade on my mower so the pull cord is too tight how do i loosen it
If you used the pull cord to hold the shaft while you tightened the blade, you damaged something in the pull cord assembly.
Sep 05, 2014 | Troy-Bilt Troy Bilt Genuine Troybilt Mower...
How do you adjust steering on a storm 3090 xp ?
howdie the Pins in the front adjust the holes According to your Height or lower them Thks For your Time
Sep 04, 2014 | Troy-Bilt Troy Bilt Storm 3090XP Snow...
Troy Bilt zero turn Mustang Xp 50" deck height. My
raise the back as high as you like but unless you raise the front as well it will still cut short. If you want it higher and there appears there is no adjustment left you may have to re thread the adjusting screws to shorter dimensions or if it is on levers you may have to drill new holes further up the bars.
Jun 02, 2013 | Garden
I need an on/off switch for a Troy-Bilt TB190BV electric blower. Troy-Bilt has discontinued this "model" and doesn't have the part. I have a oversized paperweight. Is there a solution...
When the switch went bad on my TB190BV I was able to cut the wires at the terminals and re-solder to the other side of the switch. There are free terminal on the opposite side of the switch from the factory connections. Make sure to mark all of the wires and reattach to the free terminals (You have to turn the switch 180 degrees, so you're soldering in the opposite order from the original orientation!) If you are not sure, with the motor unplugged from any power, check the pairs of terminals with a multi-meter set on ohms. The pairs with the highest ohms (highest resistance) is the off position, the pairs with the second highest ohms is low power setting and the lowest ohms is the high power setting. Before you cut the original terminals you may want to do this test to see if the current terminals are bad. If the ohms are high on all settings then the switch is bad.
Aug 26, 2011 | Troy bilt Electric Blowervacuum Tb190bv
Lawn mower
Always start by checking the spark plug. If you are getting spark and still not starting, it's probably a carburator problem.
May 06, 2010 | Troy-Bilt Pony Garden Tiller
Need to know how to change the oil in my Honda w/Troy Bilt motor 11A-542q711 w/overhead cam GCV 160.
Jun 06, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
