Question about Reebok Exercise & Fitness
David douillet crosstrainer handleiding
Hm 6007
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Hello, I have a David Douillet Treadmill and I broke it a few weeks ago.. could you tell me who or where can i call or write to order that piece??
Dear Sir:
Please go tho next web: www. treadmilldoctor.com
or go www.unitedassemblers.com
or www.fitnessrepairparts.com
and make the contact. sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 17, 2012
How do I activate the component out on the Marantz SR 6007?
You need to go to Menu/Input Setup/Input Assign. In the column labeled COMP, assign the Component Inputs (1-RCA through 4-RCA) to the various Sources.
You may need to go to each Source and turn Video Convert to On. Select an Input, such as SAT. Go to Menu/Input Setup/Video/Video Convert and select On.
Aug 20, 2014 | Marantz SR 6007 AV Network Receiver
Tip
95Xi Crosstrainer Shroud Replacement
Video Presentation of Replacing the Main Shroud on a LifeFitness 95Xi Crosstrainer
  • The video shows the steps involved in replacement of the main shroud on a LifeFitness 95Xi
  • Tools:
    • Phillips Screwdriver
  • Remove the (4) screws securing the main shroud to the drive frame assembly
    • There are two screws on each side
  • Lift straight up on the shroud to remove it
  • Install the main shroud in reverse order
    • Making sure the main shroud fits into the grooves of the lower shroud panels
Repair Video for LifeFitness 95Xi Crosstrainer Shroud Replacement
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
Tip
95Xi Crosstrainer Drive Belt Replacement
Drive Belt Replacement Video for LifeFitness 95Xi Crosstrainer Elliptical
Tools needed:
  • Philips Screwdriver
  • T25 Driver
  • T50 Driver
  • 2MM Allen Wrench
  • 5/32" Allen Wrench
  1. Remove the main shrouds as seen in the main shroud removal video
  2. Remove the left outer link cover as seen in the Outer Link Cover removal video
  3. Remove the left pedal lever assembly as seen in Sportsmith's Pedal Lever replacement video
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Walk the drive belt off the pulley and remove it from the unit
  6. Install the new belt around the crossover shaft first and then walk it onto the pulley
  7. Replace the remaining parts in reverse order
LifeFitness 95Xi Drive Belt Video How To Replace
Life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
Apr 04, 2013 | Life Fitness Crosstrainer, 9100, 9500 Rear...
Wheel bearing for 2005 chevy aveo front
wheel bearings on the aveo are pretty inexpensive and easy to replace.
Oct 10, 2012 | 2005 Chevrolet Aveo
Tip
95Xi Crosstrainer Pedal Replacement
Video about How to Replace the Pedal on a 95Xi Crosstrainer by LifeFitness
  • This video is about how to replace the pedal on a 95Xi LifeFitness crosstrainer
  • Tools necessary:
    • T40 Torx Driver
  • Remove the (4) torx bolts securing the pedal to the pedal lever assembly
  • Install the new pedal in reverse order
  • This completes the replacement of a pedal on the LifeFitness 95Xi
Life Fitness Crosstrainer 95Xi Video Pedal Replacement
on Apr 28, 2014 | Exercise & Fitness
How do i get surf
u can get it in the safarii zone. u can alos get the hm strength by finding the wardens golden teeth witch is somewere around were u get the hm surf. return the wardens teeth to him and he will give u the hm strenght. the hm surf is in the biggest hut in the safarii zone. i had the same problem but i eventually figured it out. good luck!!
Feb 20, 2012 | Nintendo Pokemon Leaf Green for Game Boy...
Dear Sir:
ernesto cuadra
Feb 16, 2012 | Exercise & Fitness
Download manual for hp pn 5188 7687
The ECS MCP61PM-HM motherboard otherwise known as the HP Nettle GL8E motherboard,
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00906137
The ECS MCP61PM-HM motherboard otherwise known as the HP Nettle2 GL8E motherboard,
http://www.algogo.com/store/products/ECS-HP-MCP61PM%252dHM-Nettle2%252dGL8E-6150SE-AM2-Motherboard.html
The ECS MCP61PM-HM motherboard otherwise known as the HP Nettle3 GL8E motherboard,
http://www.amazon.com/ECS-MCP61PM-HM-Nettle3-GL8E-6150SE-Motherboard/dp/B0045X6N1S
Which one is it?
Oct 24, 2011 | Computers & Internet
Have a motherboard in my computer that stopped working. It is MCP61PM-HM 2.2. I ordered a new motherboard only to find out that the one I ordered was MCP61PM-HM 1.0B. My question is are they compatible?
Seems like the 2.2 is a new version. It supports a
  • Phenom with Quad Core technology (AM2+) up to 9600 (up to 95 watt)
  • The link below has the specs of your original MOBO...
    http://www.softunique.com/ECS-MCP61PM-HM-Nettle3-GL8E-Motherboard-HP-ver-22-MCP61PM-HM-V22.htm
    Here are the 1.0B specs:
    MCP61PM-HM REV:1.0B SOCKET AM2 MOTHERBOARD
    Motherboard description Motherboard manufacturer's name: ECS MCP61PM-HM
    HP/Compaq name: Nettle-GL8E
    CPU/Processor Socket: AM2
    Supports the following processors:
    Athlon 64 X2 with Dual Core technology up to 5600+ (up to 89 watt)
    Athlon 64 less than 4000+
    Sempron less than 4000+
    Front-side bus (FSB) 2000MT/s (2.0 GT/s)
    Chipset NVIDIA GeForce 6150SE nForce 430
    BIOS features System BIOS core brand: Award
    Keyboard combination to used to enter BIOS: F10
    Form factor Micro-ATX: 9.6 in X 9.6 in
    Memory Dual channel memory architecture
    Four 240-pin DDR2 DIMM sockets
    Supports PC-4200 (533 MHz), PC2-5300 (667 MHz), and PC-6400 (800 MHz) DDR2 DIMMs
    Non-ECC memory only, unbuffered
    supports 2GB DDR2 DIMMs
    Supports up to 8 GB on 64 bit PCs
    Supports up to 4 GB* on 32 bit PCs
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Jul 07, 2011 | Computers & Internet
    Exercise & Fitness Logo
    115 people viewed this question
    Top Reebok Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Ross Metcalfe
    Ross Metcalfe
    Howard
    Howard
    Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
