Why doesn't my dell windows xp computer turn on
Why doesn't my dell windows xp computer turn on when I press the power button?
Activate downloading fv...
Posted on Jul 22, 2013
  • 163 Answers
SOURCE: Hardware problem, notebook is not booting
Could well be a RAM slot failure.. Try running on 1 stick of RAM and swapping the Mods around..
Posted on Feb 11, 2008
md_ehsan_1
  • 255 Answers
SOURCE: My computer will not power off when I click
1.disconnect your charger,after shutdown
2.hope your problem will solve
Posted on Jun 28, 2009
  • 256 Answers
SOURCE: Dell Mini 10 Won't turn on. When I press the
try to power drain pc first. to do that, turn pc off, remove battery and ac adapter. press down power button for 15-20 sec, then but all back in and try to turn pc on. if still no go, you may need to replace battery or ac adapter, f it still wont work, possible motherboard replacement is needed.
Posted on Mar 29, 2010
Testimonial: "Thank you so much! This was great to give me a place to start - Dell wanted to charge me just to talk to me. Thank you again!"
  • 308 Answers
SOURCE: my dell vostro 2510 won't
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Posted on Jun 18, 2011
  • 20 Answers
SOURCE: Hi I have a dell
Follow the instructions on screen in order to return to normal mode. Safest thing I would advice yo do is, back up all your important data from the hard drive onto an external hard drive and reset your notebook. this will remove the error message from your notebook. If you are able to, you should take your notebook to a qualified IT technician. I hope this helps you.
Posted on Sep 08, 2011
HP DC7800 doesn't wake up (and power switch does nothing!)
Bad setting. If you press and hold the power button, the computer will shut off. That will keep you from having to unplug it.
Jan 28, 2013 | HP dc7800 Business Desktop Small Form...
How can i log in my Delloptiplex 760 computer,when its auto logging off
If running XP
A log-on loop on your Windows XP computer is a difficult situation where the computer never completes its boot cycle, restarting intermittently ad nauseam.
This issue indicates a major problem with the boot functionality of your XP system.
Restore the computer to working order by utilizing the repair and restoration utility on your XP system disk.
Insert the XP disk into the computer.
Restart the computer.
Press any key when prompted to boot from the disk.
Press "Enter" at the first screen and "F8" at the license terms.
Highlight the drive containing XP and press "R," repairing the operating system boot files and removing the log-on loop.
or
Windows XP sometimes has a glitch when you are logging in to your user account in order to boot the operating system.
The glitch logs you in and then logs you off the account.
This problem is usually caused by one of the programs that load during the computer's start-up.
Fixing this issue is a matter of ensuring that whatever program is causing the problem doesn't start up as soon as you start your computer.
or
Power on the computer and allow it to get to the user logon page normally.
There is no need to start up the computer in "safe mode."
Click the user who is having the issue and type in the user's password if one is set up.
Press and hold the "shift" button on your computer keyboard as soon as you see the tool bar load up at the bottom of the screen but before any other program has a chance to do so.
This stops any "Startup" program from running and logging you off.
Right-click the "Start" button on the bottom left of your screen.
Select "Explore" from the menu that appears.
Double-click "Programs" from the list on the left side of the window that pops up.
Double-click "Startup."
Select all the files inside the "Startup" folder by dragging a box over them.
Right-click anywhere on the selected files.
Select "Delete" to delete those files.
Note that deleting the programs from the "Startup" folder does not delete them from your computer.
All this does is make it so that these programs no longer start as your computer is starting so that any error in the running of the programs doesn't interfere with logging in to your account.
Hope this helps
Nov 13, 2012 | Dell OptiPlex 760 PC Desktop
When istart the computer cant log in ,eventhough my user name and password is correct
or
or
Hope this helps
Nov 13, 2012 | Dell OptiPlex 780 MT Desktop Computer...
I need to reset my margins for Windows XP
Your monitor should have a button on it that says "Auto". Press that. If it doesn't have a button like that, then find one that says "Menu" and look through the Menu to find something like "Auto-config". Alternatively, you could use your monitor's menu to manually adjust the horizontal position of your screen.
Oct 18, 2012 | Dell Microsoft Windows XP Home Edition
How to repair red screen on asus eee pc sea shell
Remove any discs in the computer.
Hold the power button down until the computer turns off.
Press the power button to turn the computer on. If this doesn't work, proceed to step four.
Remove the battery and unplug the netbook. Wait 30 seconds.
Reinstall the battery and plug in the netbook.
Press the power button for ten seconds. If this doesn't work, proceed to step 7.
Insert the end of a paperclip into the reset button to reset the netbook.
The reset button is a small hole that usually appears next to the USB and other ports.
Windows 7
Create a new Notepad file.
Type this code:
taskkill /F /IM dwm.exe
Save the file as displayfix.bat in the following location:
C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
Restart your computer.
hope this helps
Sep 25, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
DELL 300M
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Sep 08, 2012 | Dell Inspiron 300M Notebook
Reboot to factory settings for Dell
Try This:
If your operating system is XP, press the CTRL and F11 keys simultaneously when you see the Dell logo after turning on the laptop, and follow the instructions on the screen.
  • Put the computer on.
  • When the Dell screen appears, press and hold the CTRL and F11 key simultaneously on the keyboard, then release them both at the same time. The Dell PC Restore by Symantec window appears.
  • Click the Restore button or press the key to highlight Restore and press the key.
A caution message appears, advising that all data will be lost.
  • Click the Confirm button, or press the key to highlight Confirm and press the key.
The Progress window appears. Once the process has begun, Dell PC the restore usually takes only 8 to 10 minutes to complete. When the restore is complete, the message 'The system recovery process was successful' appears.
  • Click the Finish button or press the key to highlight Finish and press the key.
The computer will restart.
For Vista or Win 7
If your operating system is VISTA / Win 7, press the F8 key when you see the Dell logo. It will take you to the advanced boot menu options, which include 'Repair your Computer'. Select that option and enter your password if asked, then you will see a list of options like 'system restore' and 'command prompt'. The last option says 'Dell PC restore', or something along those lines. Select that option and follow the instructions on the screen.
If in both cases, the Factory default doesn't work, then your laptop's factory image defaults partition has vanished (i.e., been corrupted / deleted). In this case you will have to reinstall the operating system with the CD or DVD shipped along with the laptop. Follow the link below to install windows XP Pro on your own.
  • Start the computer.
  • As the computer starts, press the F8 key until the Advanced Boot Options menu appears on the screen.
  • Press the down arrow to select Repair Your Computer on the Advanced Boot Options menu, then press Enter.
  • Specify the language settings that you want, and then click Next.
  • Log in as a user who has administrative credentials, and then click OK.
  • Click Dell Factory Image Restore.
  • In the Dell Factory Image Restore window, click Next.
  • Click to select the check box for Yes, reformat hard drive and restore system software to factory condition.
  • Click Next. The computer is restored to the default factory configuration.
  • When the restore operation is completed, click Finish to restart the computer.
In both cases, if the factory default does not work, then your laptop's factory image defaults partition has vanished (i.e. been corrupted / deleted). In this case you will have to reinstall the operating system with the CD or DVD shipped along with the laptop. Follow the below link to install windows XP Pro on your own.
Good Luck!
Aug 20, 2012 | Dell Inspiron B120 Notebook
My computer doesn't want to shutdown and I was using CMD comands to shutdown it ; but when I have installed again the OS in the computer ; it has begun issue in shutdown again ; but I can see tha
Try to press and hold the power button to turn it off. If there's an issue, hopefully a blue screen will show up and it will attempt to troublehshoot it.
Apr 26, 2012 | MSI Computers & Internet
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
I have installed windows 7 ultimate 32 bit in my dell vostro 1015 ,now i want to change my windows so is it possible that i install windows xp in my dell vostro 1015
Yes it is! You're going to need a Windows XP install CD and a serial key. Once you have those, we can start. Put the Windows XP Install CD in your computer, and reboot. Press F8 when the computer comes up to get into the boot menu. If F8 doesn't work, try F2, ESC and Enter. Select the CD/DVD drive from the list, and when you see the prompt to push any key, push any key. The files will load, then you'll see a Welcome to Windows screen - press enter. The next screen will show your hard drive. You're going to have to format it here, so you will lose all your files. Backup any files you need before you do this. Highlight the biggest sized partition, and press D, then follow the prompts. Now press C over the unallocated space, and choose quick format. Then press enter. Agree to the EULA by pressing F8 Windows will now begin installing. Follow the onscreen instructions and you'll be just fine. Alex
Jun 02, 2011 | Dell Vostro 1015 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
