Question about Memorex Ultra Traveldrive - 160GB USB Hard Drive
Transferring files via external hard drive to new computer
I have important files on my external hard drive that are from an old and broken laptop. I am very nervous about somehow losing these files when transferring them to my new laptop. How do I get these files onto my new laptop?
  • 23 Answers
You just need to connect the external hard drive to the new computer. Once it has connected and Windows recognizes the drive it should pop-up with the window asking what you would like to do (select the option to View Files). Also at this time open the folder on the new computer that you want to store the back-up files in. Make the external hard drive folder and the new computer folder sit side-by-side. Then while holding down the CTRL button on the keyboard click each file you want to move. When you are done selecting them - right click on any of the file selected and on the pop-up menu select "copy". Now go to the folder on the external drive and right click the mouse again and from the pop-up menu select "paste". This will just copy the file, that way you can keep the files on 2 different hard drives in case something happen to 1 of them.
Austin
We-Supply.com
Posted on Jul 23, 2013
We have a Windows XP system on a 14 year old Dell computer.. We are desirous of transferring data from that system to a new computor. My husband purchased an Acomdata Hi-speed 2.0 external hard drive...
If both your Dell and the hard drive have USB ports you may be able to download directly. Other wise you may purchase an external drive and load the data to that. The external drive almost certainly will connect by USB.
Nov 19, 2014 | Dell Computers & Internet
Synching Itunes
To Transferring Playlists
If you want not only your content but also your playlists to exist on your new computer, you will want to transfer a copy of all your playlists from your old computer. To do this, choose File > Library > Export Library on your old computer. Save the XML file that is created to your desktop.
Send the playlists file to yourself as an e-mail attachment, use an external drive, or use file sharing to move the playlists file to your new computer. Once the file is on your new computer, open iTunes and choose File > Library > Import Playlist. The import process will remove any items from the playlists that you didn't share via Home Sharing.
Source:http://support.apple.com/kb/HT4527
Alternative Method: http://helpmerick.com/how-to-transfer-your-itunes-library-playlists-to-a-new-computer.htm
Dec 02, 2011 | Apple iTunes
I recently purchased a new Cavalry external hard drive (500gb, CAUG25500), and had been using it on my Thinkpad laptop with XP. It was working fine, no problems. Before a trip I was going on, I wanted to...
1. This could be due to several things.
a. The power supply for the external drive is not working properly
b. A broken power supply connector.
c. The USB drive was disconnected improperly > that is not disconnected safely in Windows
d. The external drive controller in the USB case is defective. A new case is needed.
Mar 16, 2011 | Cavalry Storage Cavalry CAUG 500GB USB 2.0...
We have 2 Acer laptops. The screen on one is broken. Can we coonect the two by a USB cable so that we can transferr files from the broken laptop to the good one?
The bset way to do this is to have a switch or router, and connect them by network and transfer all your needed files.
the only problem you might have is, file sharing, meaning if the files you want is readily shared, but there is a way to do that. First try to borrow a montor or LCD screen and connect to the broken-screened LAptop, and try to share the files to network.
One more easier way to fo this is to install a monitor on the broken-screend one, install a USB external hard drive on it and then copy all the files you want. After copying thet, install the USB Hard drive on your perfectly working laptop and copy the files. This procedure is more easier than what you have in mind, cheaper too, because you can always just borrow a USB Hard drive or flash drive. Even a small capacity flash drive would do, it just takes more times of plug and unplug because of the capacity issue.
Hope this helps and Thank You for using Fixya.
Jan 12, 2011 | Computers & Internet
Transferring programs from old computer to new computer. I bought new laptop n I need some programs I had downloaded on old laptop.
Old computer
1. Copy all program files.
2. Go to start---->Run---->Type regedit
3. Press on computer and then click on file ---> export.
4. Chose your location and save it.
New computer
1. Add all old computer program files to the new computer
3. Go to file and click import and chose the file you exported it.
4. Restart the computer when importing done
5. Enjoy your new COMPUTER =)
By:- Hackezier Abdulhadi
Jun 21, 2010 | Microsoft Windows XP Home Edition
Question about transferring files from computer hard drive.
Is your other drive an external or an internal drive??? If external then attach it to the USB port and see it as an additional drive in My Computer. Then you can use it as any other drive.
If an internal drive then you will have to purchase an adapter that can take this drive and get connected to the PC/laptop to through the USB port. Again visible on My Computer as additional drive and can be used such.
Dec 17, 2009 | Averatec 6100 Notebook
My fujitsu laptop recently had a new hard drive installed in it ,but i want to transfer the data i have on the old hard drive that was removed from laptop to my new hard drive. I bought the all in one...
The Coolmax adapter is an USB hard drive adapter that can connect various types hard drives to your computer. This is used for testing and and transferring data to and from hard drives connected to the computer via the computer's USB port.
This Coolmax USB hard disk adapter can connect a 2.5-, 3.5- and 5.25-inch IDE or SATA hard disk to a PC. The black adapter box connects the hard disk, while the secondary power plug/adapter powers the drive. In the case of smaller notebook or SATA disks, the power cable is plugged directly into the adapter (as opposed to straight into the IDE hard disk).
The red USB cable, meanwhile, can be used to power hard disks directly from the host PC's bus via another USB port.
Connect the hard drive to the adapter as detailed above, power up your computer and plug the Coolmax USB cable into the conputer's USB port. The computer will detect and see this as an external drive, most likely as a E drive (the next drive letter that is available). Click on this drive and open to open the folder/s where your data is stored then select the folder/s and/or data and copy them, then open the hard drive on the computer and paste the folder/s and/or files onto the new hard drive.
Sep 29, 2009 | Fujitsu Siemens Computers & Internet
Unable to transfer files from an acomdata external hard drive.
Borrow a friends "hard drive docking station" and remove the hard drive from the other external drive and place in the docking station and see if you can read the drives contents. The docking stations can be purchased at Best Buy or Office Depot if you want your own. Your external drive could have a faulty power supply or you really could have a hard drive that has developed bad sectors and that is a disaster for your data. When a drive starts acting up, you really need to act and transfer important files to a new drive or burn the data to DVD's.
Apr 14, 2017 | Computers & Internet
How can a transfer my info from a broken computer to a new one?
You need to purchase an external enclosure and install the old laptop hard drive in it. Then plug it into your desktop and copy the files .
Buy it here:
http://www.cyberguys.com/product-search/?keyword=hard+drive+enclosures
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 18, 2009 | Computers & Internet
PC constantly reboots after external HD error
put in your recovery disc and follow the instructions on it, you may need to reinstall the drivers and os....i just worked on a laptop with media center and thats what needed to be done, it was the same with the rebooting and video stuff, make sure not to activate the mcafee antivirus if it's out of date or subscription is up, it will not allow your puter to run properly, the other thing i discovered with that...hope this helps hun....shia
May 21, 2009 | Gateway 827GM PC Desktop
Memorex Ultra Traveldrive - 160GB USB Hard Drive Logo
73 people viewed this question
Top Memorex Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Piyal Perera
Piyal Perera
John Anderson
John Anderson
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
