Question about Amana AP095R Portable Air Conditioner
How to clean coils on amana APO95R
My air conditioner is not cooling-I have cleaned filter and it is still happening-I read to clean coils but do not know how to. Thank you
4 Suggested Answers
  • 18 Answers
SOURCE: no cool air. blowing warm air
is breaker for condenser tripped---has it been running before -----is fan on outdoor ubnit running?
Posted on Jul 02, 2009
skrbin
  • 121 Answers
SOURCE: my portable amana air conditioner ap125d will not
decrease a temp. on thermostat
Posted on Jul 05, 2009
  • 387 Answers
SOURCE: I do not know how
you might try unpluggging hte unit for a munite and plugging it back in to see if it resets. close all unused rooms on really hot days like we are having. clean the filter as well Hope this helps
Posted on Jul 23, 2011
My Amana AAC101SRA doesn't cool like it used to. We have cleaned the filter, but that doesn't seem to help. Should we call a repairman or think about getting another unit?
Is the outdoor coil blocked? Is the outdoor coil clean? Is the compressor running when you start unit. When you turn unit off after running it can you hear a hissing sound from within?
Aug 02, 2011 | Amana High Efficiency AAC101SRA Air...
I do not know how to set the air conditioner (Amana ACC085R) for lower temperatures. I want it to go to 70 when it's reading 78. Thank you. Also, I have cleaned the filter and coils so that's...
Jul 23, 2011 | Amana ACC085R 8000 BTU TOUCH/REMOTE ROOM...
I feel that my Amana 14000BTU is not cooling the living room enough, it is on 83farenheight, what can I do to make it kick out cooler air
Make sure the filter is clean and that the air flow to the inside and outside is not blocked. It could have a freon leak. See if the coils behind the filter are iced up. That's a sign of low freon.
Jul 22, 2011 | Amana Heating & Cooling
IT RUNS AND RUNS AND NEVER REALLY COOLS THE HOUSE DOWN
Clean the coils both of them and then use a good air filter not something that you can read the paper thru. You can use a garden hose to clean the outdoor coil the indoor coil you have to be careful not to get things wet.
Jul 02, 2011 | Goodman GPC1342H21A Air Conditioner
Should the unit be recharged at some point? I don't think my a/c is blowing very cold air, just cool.
Sometimes they leak and need to be recharged. There are other things to check first. #1 being filters. Then make sure your coils are clean, inside coil and outside coil. If all is well then you will have to get someone to check the system pressures to determine if it needs to be charged.
May 02, 2010 | Amana Comfort Zone 12M32PBEH Air...
Need On-Line Manual for Amama Portable A/C #APO95R
homeappliance.manualsonline.com/ex/thread/view/.../357803
Portables do not need venting.
Jul 07, 2009 | Amana AP073M 20" Portable Air Conditioner...
No cool air. blowing warm air
Jul 02, 2009 | Amana Heating & Cooling
Our air conditioner is running, but the air isn't very cold.
If the tube you are referring to is the larger of the two, it may be that one of these conditions exist.
Inadequate airflow over the indoor coil due to:
Plugged air filter
Plugged indoor coil
Blower not running to speed
Blocked return air or blockage in the ducts
Blower wheel fouled with debris
In some cases damaged valves in the compressor will cause the tube to ice up.
May 20, 2009 | Amana Comfort Zone 12M32PBEH Air...
Amana APO95R Turning Off/Tank Light (!) On and Off
There are only two items that will shut it down after it is set to run. The bucket full which you took care of and low humidity in the area it is being operated in. Low humidity would not constitute a reason for returning it.
Jun 15, 2008 | Amana Haier AP095R Air Conditioner
Amana AP095R Portable Air Conditioner Logo
26 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
