Question about Westinghouse Dishwashers
No power power just died to machine and wouldn't turn back on
    Top Expert:
  • Westinghouse Master
  • 12,223 Answers
Test this steps and fix it.God bless you
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Switch
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Posted on Jul 23, 2013
Pontiac g6 drive the car a bit went somewhere got out came back 2 hours later all it did was turn over an wouldn't start has plenty gas left it alone for a bit try to start it it fired right up. So I...
flassed less engine power wth????????? Flashed reduced engine power ! Electronic throttle control problem ! Your best bet ,take it to a GM dealer , buick , cadillac , GMC . You do not have diagnostic test equipment or knowledge to even diagnose this.
Jul 06, 2017 | Cars & Trucks
After you push the power button you hear a POP sound and it dies. It previously wouldn't release the door lock.
Most deadbolts use a cylinder lock. In the cylinder lock, the key turns a cylinder, or plug, which turns an attached cam. When the plug is turned one way, the cam pulls in on the bolt and the door can open.-----------------------------------------------------------------------------------
Launch Creader CR-HD
Mar 11, 2013 | Cars & Trucks
I have a sumvision cyclone voyager 7 It wouldn't turn off and after battery died it won't turn on even when plugged in Any suggestions? Thx Dave
Sounds like you may have a dodgy power button, you have a 1 year warranty I would call or e-mail sum vision, I have one of these systems and there not bad I've not had a power button problem though. Hope this helps!
Jan 02, 2013 | Audio Players & Recorders
This t.v. was working fine until today i turned it off for 15 minutes then it wouldn't turn back on at all.There is no sign of power what so ever!
Power supply has died. But I will need the model number of the set to assist further because some models actually get the power on command from the main board
Dec 10, 2012 | Televison & Video
Car ran fine shut it off came back it didn't want to start. started went about half a mile sputered an died wouldn't start back up 1991 subaru loyal wagon
Hi sounds like the typical fuel pump or filter problem with these cars, best way to tell is take top fuel hose off on fuel filter under hood, turn key on ignition (not start) and fuel should pump out, if not its your pump, just beware of doing when engine is hot
Apr 22, 2012 | 1991 Subaru Loyale
Starts and then dies.
Check to see if your getting spark but before that check your fuel inertia switch not sure where it is located probably in trunk you may get lucky
Dec 14, 2011 | 2002 Ford Taurus
I've just bought one. Is it normal that the hand wheel is hard to turn. Does not that put stress on its motor?
hi, if you just bought this machine, my suggestion is to take it back & get another one.
the handwheel is not suppose to be hard to turn when it's brand new.. I've been sewing for over 30 years & I wouldn't keep the machine, I'd take it back & get another that works properly.
Sep 23, 2011 | Singer 8280 Mechanical Sewing Machine
I used my dryer this morning with no problem. I came back to use it this afternoon and it wouldn't start. I checked my power box and turned everything off and back on, but the dryer still wouldn't...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 07, 2011 | Dryers
I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Dec 11, 2010 | Samsung Washing Machines
How to clear c-0204
C0204 - Tray 2 Elevator failure - The Lift-Up Sensor is not blocked even after the lapse of a given period of time after the lifting motion has been started.
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Nov 23, 2009 | Konica Minolta bizhub C250 All-In-One...
Dishwashers Logo
180 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
