Question about Microwave Ovens
Westinghouse microwave WM009 is not heating up. what could be wrong with it?
My microwave model number is WM009. I am unable to change the current clock time. How do I do this?
push clock the up or down then clock again till its set then start
is what I would try
Dec 21, 2016 | Microwave Ovens
Touchpad on Westinghouse Microwave not working
From the description the whole keypad control board will need to be replaced, but keep in the part is more expensive than some brand new microwave oven.
Apr 20, 2012 | Westinghouse WST3504 Microwave Oven
Help. got a problem
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 22, 2011 | Westinghouse Microwave Ovens
How many watts are on the wst3501 microwave oven?
Westinghouse WST3501 Microwave Oven 0.7 model or 700 watt
Good luck (remember to rate this answer).
Apr 08, 2011 | Westinghouse WST3501 Microwave Oven
Westinghouse wmg281sf microwave Microwave (mw) less than 6 months old and after selecting start the mw makes a noise that seems to come from the light and during operation impedes the power source to the...
Hello mbz... Since the operation is impeded, the problem is more than the light bulb. This unit has an internal short, and should be under warranty for the first year. Return it. Joe
Thanks for choosing Fixya!
Dec 16, 2010 | Westinghouse Microwave Ovens
My westinghouse refrigerator has stoped working but my freezer is working fine help. Model Bj513V Serial Number 72656346
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 18, 2010 | Westinghouse Microwave Ovens
Display on my westinghouse microwave says CHIL it wont work now
hello,
what you are to do to fix up the problem is that,put iff the the oven for some time and allow it to relax it self with out an operation, then put it on again then if it has time programming or reset button then click on an of this button for it to restart it self ,
but if this problem remain then you will have to open the the oven then trace the wire down to the panel to clean up any from of dirt or liquid around the panel then couple it back at it was with this the problem will be solve.
thank you and thanks for using fixya.
Jun 14, 2010 | Westinghouse WST3504 Microwave Oven
Need owners manual for Westinghouse microwave Mod.#WST3507SS.
Contact Westinghouse Small Kitchen Appliances at 800-245-0600 or 800-947-3745 or visit here.
Mar 02, 2009 | Westinghouse WST3504 Microwave Oven
Microwave shuts off about 10 - 30 after starting to heat an item. Display flashes PF. Which I figure is power failure. Unit is 5 months old and has very little use. Model WES1130DM1WW purchased at...
It should have a one year warranty, right? If so, Westinghouse should take care of it for you.
Contact Westinghouse Small Kitchen Appliances at 800-245-0600 or 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 21, 2008 | Microwave Ovens
Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
Dec 10, 2007 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
140 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
