Question about Innovage Speaker/Caller ID* LCD Touch Panel Phone with 12-Digit Calculator
Caller ID doesn`t talk
When the phone rings, the caller ID does not tell me the number.
  • 3 more comments
  • kelleyp Dec 11, 2007
    When the phone rings it does not annouce the caller number like it says it should. My phone is a Innovage Touch-Panel Caller ID Speaker Phone with 10-Digit Calculator
  • Anonymous Dec 27, 2007
    the phone does not talk and tell me who is calling like it says it is to do
  • hmod Dec 29, 2007
    talking is not working
  • ndriv Apr 14, 2008
    I have the same problem. The Caller ID displays _ _ _ _ _ _E_ _ _ _ _ It does not display the number. Does anyone know why????
  • Anonymous Aug 21, 2008
    NO VOICE
  • 32 Answers
Only thing i can think is the IP function might be on. ( and of course, u do have the caller id through the phone company activated, right,,,,just checkin) . this funtion is not available in the USA. to turn it off, press SET/SAVE, press UP to select SET 4 AUTO IP, press SET/SAVE to select, press UP to turn on and off, then press SET/SAVE to confirm. hit DELETE to return to main screen. hope that helps.
tammy
Posted on Aug 12, 2008
6ya staff
SOURCE:
My new Hp Officejet j3680 caller ID is not working... All the phones in the house display the incoming phone numbers except the j3680. I wonder why?!! it shows instead ringing!!!
The caller ID phone having the tip & ring detection circuit to detect the incoming phone number, but in this model doesn't have tip & ring detection circuit to display other phone number but after connecting the other fax it will read the information which was stored like company name & phone number of other one..
Jan 04, 2012 | HP J3680 Officejet All In One Printer
We have 3 phones in the house. I want caller ID on each of them. Called AT&T and caller ID appears on only one phone - UNIDEN in the kitchen. Phone on same floor AT&T in living room and AT&T...
unplug the one that gets caller ID and one more. Do you get caller ID on the remaining phone?
Caller ID is sent between the first and second ring, as well as the second and third ring. It may be that the other phones require that 2nd Caller ID signal and you've answered it elsewhere.
I am assuming that the other phones have a display and are Caller ID capable phones.
Can you post the model numbers of the phones that don't get Caller ID? We can then try to locate a user guide for them.
Sincerely,
Mark
Apr 01, 2011 | Cell Phones
How do you turn off talking caller ID on panasonic kx-tg4032?
This feature lets you know who is calling
without looking at the display.
To use this feature, you must:
- subscribe to a Caller ID service of
your service provider/telephone
company.
- turn this feature on (page 24).
When caller information is received, the
handsets and base unit announce the
caller's name or phone number received
from your service provider/telephone
company following every ring.
The unit announces in English only.
L Name pronunciation may vary. This
feature may not pronounce all names
correctly.
L Caller ID service has a limit of how
many characters can be displayed. If
the caller's name is too long, the
handset may not be able to display or
announce the entire name.
L The announcement is heard at the
same level as the ringer volume (page
16, 23).
L If you turn on the answering system
and set the number of rings "2
rings" (page 36), the unit does not
announce the caller information. If
"Toll saver" is selected and there
is a new message, the unit does not
Mar 24, 2011 | Panasonic KX TG4032 19 GHz Twin Cordless...
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
Please ..need to know how to get other call on call waiting.. cordless phone 5.8
Adding call waiting as a feature to your telephone can help you take calls that you are waiting for without having to stay off the phone until that important call comes in. With call waiting, you get a beep when you are on another call to let you know that another call is coming in. If you want to take the call, you follow the simple steps outlined in this article.
  1. ep 1 Order call waiting from your phone provider if you do not already have it. Cal waiting works best with caller ID features that give you the phone number and name of the person calling you. Phone numbers that have blocked numbers or use *67 to mask their caller ID will not show up on caller ID.
  2. Step 2 Take a call when your phone rings. While you are talking on the phone and hear a beep, you are receiving another phone call. Using your caller ID function, whether it's on your answering machine or on your handset for the telephone, see who is calling you. If you want to talk to them, quickly press your "talk" button to put the other call on hold or disconnect. Press "talk" again to take the incoming call.
  3. Step 3 Disregard the other phone call if you do not want to terminate the call you are on. The new call coming in may go to your answering machine. Or if you have the call back feature on your telephone, you can simply call *69. Your phone will dial the number of the person whose call you just missed.
  4. Step 4 Use call waiting as politely as you can. You might tell someone who you are talking to that you are expecting an important call and may have to terminate the call abruptly. Call waiting calls should be answered as quickly as you can. After four rings, most phone calls go right to the machine or people hang up. Promise to call your first caller back if you have to interrupt the call
Nov 15, 2009 | GE 25942GE2 Cordless Phone System
Caller id question
Call your phone company.. They should be able to assist you and tell what additional equipment, if any, you will need to have this.
May 01, 2009 | Panasonic KX-T7736 Corded Phone (KXT7736)
KX-TG9344
This is the info from the users manual, it seems a bit strange,
but claims if you set the number of rings before it answers, (for the answering system) to "2" it will stop the audible caller ID.
Here it is from the manual.
and set the number of rings “2” (page
38), the unit does not announce the
caller information. If “Toll saver” is
selected and there is a new message,
the unit does not announce the caller
information.
When you receive a call while on the
phone, the 2nd caller’s name is not
announced even if you subscribe to
both Caller ID and Call Waiting with
Caller ID services
Jan 02, 2009 | Panasonic KX-TG1033S Cordless Phone
CALLER ID & NUMBER TALKING
You must be kidding. You want me to pay you to solve my problem. Yet, you want me to tell you if I solved it, how I did it. Well I solved it but it will cost you to find out how I did it.
Have a nice day.
Mar 29, 2008 | Sakar Talking Caller-ID Speaker Phone
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Feb 19, 2008 | Panasonic KX-TG6071M Cordless Phone
Innovage Speaker/Caller ID* LCD Touch Panel Phone with 12-Digit Calculator Logo
231 people viewed this question
Top Innovage Lands Phones Experts
spiritsoul
Level 1 Expert
Damen Wong
Damen Wong
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
