model ET18PKX6HB1 is leaking water from the device mounted on the back interior wall that connects freezer to main unit. Device is a 3'' wide, 1/2'' deep hood with opening at bottom that drips water. This has hapened twic in the last several days and once it starts dripping it stops within about one hour.
The drain is clogged up. Check the clear plastic line that goes from the back to the drip pan on the bottom of the unit.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
I found the drain located behind the panel inside the back of the freezer to be covered with ice. Used a hair dryer to clear drain. Heater was working
" - wthompson470
whirlpool et20dk refrigerator has 60 degree main area frig temp and 5 degree top freezer temp. What...
(More)
whirlpool et20dk refrigerator has 60 degree main area frig temp and 5 degree top freezer temp. What is the problem. Thanks
look like it quit working I got it out part#2252129 is there a way I can make sure this is not...
(More)
look like it quit working I got it out part#2252129 is there a way I can make sure this is not working????
Whirlpool side by side refrigerator, model ED2JHGXRT00, the ice dispenser level (black) is broken....
(More)
Whirlpool side by side refrigerator, model ED2JHGXRT00, the ice dispenser level (black) is broken. Part is on order. How do I get the door apart to install part?
i just noticed that my ice maker is not making ice so i moves things around then it sounded like it...
(More)
i just noticed that my ice maker is not making ice so i moves things around then it sounded like it stopped running but the lights are still on can u hear your regfrig running or does it run constanlty
eveporator deforsting at the bottom and the top not defrosting .the deforest thormostat and heating...
(More)
eveporator deforsting at the bottom and the top not defrosting .the deforest thormostat and heating eliment is good ;this fridge used electronic timer.what must i do.
