Question about Microwave Ovens
I need a replacement Magic Chef microwave oven for MCD990ARS
fridgetech
  • 473 Answers
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Posted on Oct 05, 2007
  • 958 Answers
SOURCE: microwave
im not sure what a magic chef bulb is but you can check by opening the casing, the bulb is normally mounted on a fiber board and screwed on the metal part of the microwave,remove the two wires attached to it first, after unscrewing the screw, you can pull out the bulb holder and you can see if it is a replaceable bulb if it has a socket. you can use the old bulb holder , just replace the bulb. in some design, the bulb is mounted directly to the bulb holder, you have to buy the bulb mounted directly to a new bulb holder and use them all as an assembly. be sure to screw them back tight. tnx. i hope i was able to help.
Posted on Feb 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Oct 20, 2008
SOURCE: Microwave waveguide spatter shield burned through
THE PART IS CALLED A WAVEGUIDE COVER AVAILBALE FROM REPAIRCLINIC.COM
Posted on Mar 02, 2009
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
My magic chef microwave died. I replaced fuse, and electrical works but won't cook. Why?
Most likely if the fuse blew the part that creates the microwave energy is defective, it is called the "Magnetron" Just replace the oven is my suggestion.
Nov 11, 2016 | Magic Chef Microwave Ovens
Magic chef microwave buttons will not work but microwave is on
its a connection problem probally from a bump while driving the camper - you can dismantle the microwave yourself from the back and reconnect the jared wiring, or just replace it with an industrial one that can handle the camper abuse.
Jan 04, 2014 | Magic Chef MCD990R Microwave Oven
Magic chef microwave lamp replacement model mcm1110b
Most lamps are replaced from a door on the side of the oven
Nov 29, 2013 | Magic Chef 1-1 Cu Ft Microwave Oven -...
Magic Chef MCO160UQ Carousel turning slowly
The turnable motor is going, the buzzing indicates the magnetron is about to fail. I suggest using the microwave oven until it dies and replace it, not cost effective to repair.
Apr 14, 2012 | Magic Chef MCO160UQ Microwave Oven
Magic Chef Microwave runs but no heat produced,
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uitot
May 11, 2010 | Magic Chef CMV1000B Microwave Oven
No heat on magic chef microwave
Dec 29, 2009 | Magic Chef MCD1311ST Microwave Oven
Fuse replacement of Magic Chef MCD990W
you'll need to completely remove outer cover its under the outer cover,be very careful inside even unplugged it can store 2000 volts on the capacitor for sometime
Jul 13, 2009 | Magic Chef MCD990W Microwave Oven
Replace light bulb in Magic Chef MCD1611
Remove cover and look for light. Special torx is required to loosen screws.
Feb 19, 2009 | Magic Chef MCD1611 Microwave Oven
NEED TO ORDER GLASS COOKING TRAY FOR MCD990ARS PART #3517203500 OR FIND STORE IN AREA CODE 48316 THAT WILL HAVE THE GLASS TRAY.
check this site :http://microwaveglasstrays.com/shop/microwave-glass-trays-c-21.html. search for your brand name buy online.
Jul 24, 2008 | Magic Chef Microwave Ovens
Microwave Ovens Logo
64 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
