Question about Garden
Setting Idle Speed
How can I set withoug a tecometer the throttle and idle on myu 1985 honda spree?
  • 2,239 Answers
Sorry but you need a taco to set the high free load running, if you excede the maximum revs you run the risk of seizing the engine.
Posted on Jul 23, 2013
sparksflyin
  • 47 Answers
SOURCE: Engine runs but wont idle!
set you carb adjustments at 1 1/4 and try that
Posted on Feb 08, 2009
lemmingleejn
  • 173 Answers
SOURCE: MY HUSQVARNA 136 CHAINSAW WILL NOT IDLE DOWN. IT
This sounds like a sticky throttle cable.
Check that it's route is un-inhibited.
Though, the cable itself may be freyed, and thus in need of replacing.Happy and safe chopping:)
Posted on Jul 27, 2009
dontbother10
  • 2220 Answers
SOURCE: Model 3400, runs on idle but not at full speed,
I think like you it is running lean. Normally I would provide a link to the IPL (exploded parts list) for your saw but Poulan just locked the site for non-dealers. Please register your displeasure here http://www.poulanpro.com/node4020.aspx. IMO as an owner, you should have free access to these.
Sounds like time for carburator kit, HTH
Lou
Posted on Sep 26, 2009
dontbother10
  • 2220 Answers
SOURCE: Husqvarna 359: Has run fine for 3 years. Now when
I think an air leak and she is running lean. Maybe time for some pressure/vacuum testing. Continuing to tweak the carburetor may camouflage a larger problem until the saw fails.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 05, 2010
  • 2239 Answers
SOURCE: started 455 rancher after setting
This sounds like the throttle spindle sticking, or the cable sticking, if you remove the top cover and air filter, then push the throttle spindlefully back to the stop screw with your finger, then try again, the spindle may be a little gummed up.
Posted on Mar 18, 2011
I have a 1986 honda prelude2,0si pgm-fi programed fuel injection 12valve.my car in allgears starts bogging out,towards the end of gears.
1985 Vf750F - Bogs Down On Throttle - Maintenance Questions - VFR ...
www.vfrdiscussion.com > ... > Maintenance Questions
Jan 22, 2014 - 10 posts - ‎4 authors
Page 1 of 2 - 1985 Vf750F - Bogs Down On Throttle - posted in Maintenance Questions: Greetings VF braintrust! I have a 1985 VF750F which I ...
Honda Spree and Elite 50 Forums • View topic - 1986 honda spree ...
www.hondaspree.net/phpBB3/viewtopic.php?f=3&t=18521
Apr 9, 2011 - 12 posts - ‎4 authors
Hi all I am new to thie forum. I recently bought a used rebuild Honda Spree. The guy I bought it from ran super unleaded in it and mixes klotz ...
250 bogging down under full throttle. - Honda Rebel Forum
Dec 02, 2015 | Power Flow 1986 - 2001 Honda Prelude Mud...
How many turns in air screw?
turn the mixture screw all the way in then back it out between 1 1/2 turns to 2 turns
that will get the engine to idle from there set the idle speed with the throttle screw to desired idle rpms
now turn the mixture screw in slowly until you see/hear a fall in rpms
now screw the screw out until again you hear /see a fall in rpms.
half of the number of turns back in from in to out will be the desired air /fuel mixture setting
adjust the idle with the throttle screw if it has altered
you can repeat the procedure again to fine tune the mixture after adjusting the throttle screw
Sep 14, 2015 | 2006 Hero Honda Splendor+
Setting idle
If you have carbs:
http://www.bikebandit.com/2005-suzuki-boulevard-c90-vl1500-carburetor/o/m147639sch503698
Part #60 adjusts both carbs' idle speed evenly.
If you have throttle bodies:
http://www.bikebandit.com/2005-suzuki-boulevard-c90-vl1500-throttle-body/o/m147639sch506971
Part # 14 should adjust the idle speed on both.
Apr 20, 2014 | 2005 Suzuki Boulevard C90
Exhaust smoke at idle speed
What color of smoke?
Black means too rich....adjust idle mixture.
Blueish means oil burning...bad rings, bore or valve guides
Whitish means moisture...condensation...should burn off after several minutes, regardless of throttle setting.
Dec 04, 2013 | Motorcycles
Honda gx160
Kescorpio56:
Check your throttle and choke settings. Something is causing the throttle plate in the carburetor to remain open or the governor is improperly set. I would reset the air/fuel mixture screws to one and a quarter turns out and back the idle screw all the way out. Make sure that the throttle cable operates the throttle properly and check the governor setting and reset the governor setting if needed. Start the engine and adjust from there. When the engine starts, adjust the idle screw until the engine idles. Adjust the fuel/air mixture screws for the best idle. Then run the RPM up and adjust the fuel/air mixture screws for the best run/idle combination. Don't forget to adjust the governor if the engine runs too fast or too slowly.
May 31, 2013 | Air Tools & Compressors
On small 1985 14 inch craftsman chansaw what is the high and low settings set on the carb
Not knowing the model, you can always look on the body of the carburetor, there should be an "H" for the high speed mixture screw and an "L" for the low speed or idle mixture screw. Both screws should be set initially 1 to 1 1/2 turns out from seat and then the carb. will have to be fine tuned from there. The high speed screw is adjusted when the throttle is in fast position, at 1 1/2 turns out you should have a slightly rich mixture so you may need to slowly turn it in until you hear the saw's rpms start to increase. You want to find a medium point between too rich and too lean. The low speed or idle mixture screw is set the same way just at idle rpm instead of full throttle, find a medium between too rich and too lean. You should be able to throttle form idle to wide open without any "lag" or "stumbling". You can also offset any rpm change at idle with the idle speed screw (not to be confused with the idle mixture screw). Hope this helps.
Feb 13, 2011 | Garden
How do i set idle for 25cc gas trimmer?
look on the carb for two screw's sticking out they should have plastic guards on them just take them off and adjust the set screw's until its right it should smoke very little when right and not run very fast!!!
Aug 18, 2010 | Craftsman 25cc Gas Line Trimmer
1985 Nissan Sentra Hatchback Manual Idle Speed Is Much Too High
If you contaminated the throttle cable with lubricant, you HAVE to REPLACE IT. They are dry on purpose - so they do not collect and cake up with crud. This WILL cause it to bind, usually at partial or full throttle and then where will you be? ;) Get that fixed and then consider this:
If it is a carburetor engine (non fuel injection) likely cleaning the throttle linkages, springs and plates with carb and choke cleaner from a spray can will get the parts clean and loosened up. Some of those designs incorporated a weighted cam/ratchet to set idle speed when the engine is cold. As the engine warms, this cam/ratchet uses gravity and bimetal spring to fall back and allow the throttle plates to rest at normal, low, warm idle speeds. Crud, light rust, dry parts will prevent this from operating properly. I once serviced a Dodge B250 van for this very problem because *mud dobber wasps* decided to build a nest in the throttle linkages!
May 10, 2010 | 1985 Nissan Sentra 2 Door
Where is the idle control valve-1985 honda accord
there is no manual adjustment all handle by ecu it should be near throttle
Jul 21, 2009 | 1985 Honda Accord
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
