Question about Uniden Radio Communications
Uniden grannt xl will not transmit
I have a 17 year old uniden Grant XL. Some days it will transmit sometimes it will not. I can't link the problem to temperature, moisture, vibration, solder joint, or a cracked board. The mic is OK. The am regulator, final and driver on the back of the radio have been replaced. The audio chip on the side of the radio has been replaced. TA7222P and the voltage regulator on the side of the radio near the audio chip checks out OK also. I noticed the meter will go in the wrong direction when the mic is keyed when it does not transmit. What other components do I need to check? It's a great radio when it works. Is there someone who can help me with this problem?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
I can tell you that mic wires can simulate that problem when they accidently touch or ground out. Sometimes a ground is loose or capacitor leaks. Check standing wave ratio. SWR 1.5 or less prefer 1.2 or 1.3 read. Antenna cables replacement and new ends. Dirt in mic switch. Mine did this with a power mod capacitor
near final(without proper discharge 100 ohm resistor). I turned back power to 1 1/2 watts to 4 swing a Tx tuning slug *redpaint on it. I let it talk on low key an when i speak it jumps to 4 or 5 watts on meter. When a mod has been done some people don't know that capacitors discharge and it will leak back current. Thats why on a Cobra/Uniden company radio the instruction properly call for a 100 ohm resistor to be placed in parallel with Capacitor near final on bottom of circuit w/ capacitor on top spkr side(i call it top its on spkr side bottom when radio is upright (super mod kit). Or replace jumper J1 to factory deadkey of 4 watts and see no swing in talk except to 4.5 watt slightly(factory tune)
Posted on Jul 22, 2013
2 Suggested Answers
  • 32 Answers
SOURCE: Uniden Grant XL No Transmit
on the back of the radio you will see a small circuit board with a transistor on it this is your am regulator.check to see if that has gone bad
Posted on Feb 02, 2009
Why does the uniden granr xl go into the transmit mode when turned on
Wrong Microphone, Shorted leads in the microphone plug or a bad transmit switching transistor.
Aug 17, 2014 | Uniden 2SC1973 Transistor for Grant and...
Why does the uniden grant go into transmit mode when turned on
if this happens without a mic attached, it is common for the tx/rx switching transistor to fail
Aug 16, 2014 | Radio Communications
How to adjust frequency on a uniden Grant XL
Take this to a shop that does it for a living, they have the correct equipment needed to align this rig
Mar 08, 2014 | Uniden GRANTLT 40-Channels Base CB Radio
Need owners manual
go to www.cbtricks.com they have your manual.
Feb 03, 2014 | Uniden Radio Communications
Need wiring diagram for uni den grant xl mic
4pin version.. newest models
1ground
2audio
3tx
4rx
5pin older ones
1- Audio
2- Shield
3- Receive
4- Sw Com
5- Transmit
Oct 12, 2013 | Radio Shack TRC-447 CB Radio
Uniden president grant stops transmitting wait 1 or2 minutes and it will transmit for a little bit then does it again never lose my recieve thank you for your intrest
i cant afford 20 dollars to fix that radio your add said free i am laid off the old grant will have to waite i am not a teck have no idea what is wrong thank you for your time sorry to bother you ihave a good ole cobra29 that i talk on now grandadmac50@ yahoo.comm
Jan 30, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Jan 27, 2009 | Radio Communications
Need manuel
I am assuming this is a CB radio, and i've found a manual for the LT model, found below, but not the XL. It takes you to Uniden's website. You may have to contact them directly if this doesn't help you out. If you haven't already, check the label on back for the model #. It may be listed that way, as there are some XL models listed.
http://www.uniden.com/index/manuals_results.cfm?cat=5
Good luck, and please remember to rate my advice.
Feb 28, 2008 | Audio Players & Recorders
Radio Communications Logo
113 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
