Question about Home
I have a Parisi Envy WC soft close seat that moves!!! I want to move the seat from the Post holder to tighten the post holder. The Two slidding part will not move off the holding part as it loose.Is there a tool that can facilitate this? I have removed 4 phillip head screws.
SOURCE: We have 3 soft closing Toilet seats.Newly
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
Posted on Aug 01, 2009
radar001
  • 1051 Answers
SOURCE: loose toilet seat
If the screws don't tighten the either the screw threads are stripped or the attachment nut is stripped. Take the screw and nut to any hmoe repair center and get new ones. remember don't over-tighten then screws as this will crack the unit.
Posted on Feb 11, 2010
farmerbear
  • 490 Answers
SOURCE: I bought a new Jacuzzi toilet and from day one the
Three wraps of white teflon tape on the threads will often help to keep the assembly tight longer. Since the fastener is made of nylon, there is not really any sort of glue that will work.
Posted on Aug 20, 2010
SOURCE: The close coupled toilet seat keeps coming
I too could not figure out how to get to the nuts since the skirt completely encloses the base. Nor could my plumber until he called his plumbing supply store. They told him they use a type of rubber piece that can be pushed through the hole from the top and acts as a nut. I didn't see it replaced so I don't know the details but I do recall that when I tried to turn those phillips screws that there was a squishy feeling. I don't know how to tighten under those conditions. I recommend you call a plumbing supply store.
Posted on Aug 21, 2010
heatman101
  • 43501 Answers
SOURCE: The toilet see is not
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Posted on Aug 29, 2010
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
How do i fix a soft closing toilet seat
some of these have bolts under seat...you turn seat to left or right by grabbing while in closed position...this will release the seat from the holding bolts...then tighten the bolts....then reset the seat on bolts then lock down by doing the opposite as you took off...
Oct 10, 2014 | Home
How to remove a parisi nahm soft close toilet seat
there is 1 of two ways.
easy way is have a look where the seat mounts to the toilet and see if there is a cover that you can lift up and find a screw under it. there might be 2 pins on each side of the toilet seat hinge that you depress for you to remove the seat from the hinges to access the screws.
failing the above method the toilet has to be removed to access the screws / wingnuts from under neath. send closer picture of hinge on seat if you like.
Jul 12, 2014 | Toto Aquia II Dual Flush Toilet
How does the YB2808 holder detach from the wall? ......the above answer wasn't an answer....I need to know how to "unsnap" the thing....it IS NOT held on with typical allen screw, how does one...
The anchor is put into the wall in a pilot hole, a mounting post is inserted into the wall anchor, Afterwards the mounting post is pressed firmly until it clicks to stay in the mounting post with the handle down. The locking tab on the mounting post is faced down to fit into the specific area to stay put.
  • If this was over tightened it will be difficult to get off.
  • Try moving the handle from side to side, while pulling the unit off.
  • If all else fails, put tape around the handle, then slide a flat head screw driver under neath, and lift up. the anchor bolt will now want to come out but it can be cut off. Push it back in. Repair the hole and try again if you are moving it anyway.
Dec 10, 2010 | Moen YB2808 Eva Paper Holder - Chrome
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
I have a 2007 ford fusion and i was driving one day and placed the seat belt behinf the headrest and now it is locked and there is not enough slack to move it. how do i get it unlocked ?
Try this:
1. On the door post, the belt holder can slide up and down. Slide it to loosen the belt tension, being careful to not let the belt tighten.
2. If no belt slack, try adjusting the seat back either lean forward or back, if possible.
3. You may have to move seat back / forth and adjust seat back a certain way.
Sep 24, 2009 | 2007 Ford Fusion I4 SEL Sedan
Seat moves side to side
make sure the seat post is securely tightened into the frame. then there are a few screws (normally 5mm allen wrench) that are on top of the seatpost but under your seat, line up the seat and tighten those screws. those are the only things that could cause your seat to do that. unless one of the seat rails is broken. hope this helps
Aug 07, 2009 | Cycling
Eight-way power driver?s seat broken!!!!!!!!
check the relay for the power seat(s) located likely under the dashboard in the fuse panel
Mar 16, 2009 | 2006 Chevrolet Impala
Agitator moves slowly on wash cycle/not at all on spin cycle
it sounds like the dogs are worn. try twisting the agitator post by hand,it should move freely in one direction then lock up going the other.its a pretty easy fix if they are.pry off the top of the agitator post off then remove the cap inside,there is a bolt that holds the post down.i'm pretty sure it's 7/16 in. once the bolt is loose,lift the whole agitator out of machine and with your hand inside post turn it upside downand let the dog holder slide out.watch how the dogs fit into the holder, replace with new dogs and reverse the removal process.
if the machine wont spin, check the lid switch. thats usually the cause of a no spin situation.other than that a wet vac is your best bet.hope that helps.
Nov 29, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Home Logo
121 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
