Question about Dryers
Maytag neptune dryer repairs
Display reads 44 but we can't change any settings on dryer. It worked fine a couple of hours before. Hoe do we fix this?
    Top Expert:
  • 12,223 Answers
Please go to this website
http://www.applianceblog.com/category/dryers/
search for your model, and download the model ,etc, for service repair manual, and look for you manual pdf. However you can go in diagnostic mode, for to see what going on in your dryer.
God bless you
Posted on Jul 22, 2013
  • 146 Answers
SOURCE: change rollers on a Maytag Neptune Dryer
You have to work from the front. Pull the top then the front then you will be able to see everything. Pretty self explanatory.
Posted on Dec 22, 2007
SOURCE: Maytag neptune dryer won't start
Hey all neptune stricken owners - I removed the circuit board which was darkened substantially in the resistor area, but the maytag repairman got no money this time!! . . . And the cold is no longer the problem it has been for the past couple of years. We replaced the 3 main capacitors(blue) and the cluster of four resistors(brown) - and voila - the dryer works like new!!! It only cost a few bucks ($.67, $.92 etc etc) as opposed to the $151 a new board was going to cost!
Posted on Jan 20, 2008
SOURCE: Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Posted on Nov 21, 2008
SOURCE: Maytag Neptune sensor and time drying settings
Fixed the problem, not the machine, needed a new dryer vent. Just unhooked the vent and
the dryer worked perfectly. V
Posted on Feb 09, 2009
  • 351 Answers
SOURCE: Maytag Neptune Dryer smells like burning rubber or plastic...
could be the board, could be a motor, could be a belt but i would run it intill something just stops or try your best to take it apart and look through things and see if you can see an indication.
Posted on May 09, 2009
Have maytag neptune dryer md68. Lights are working but will not run.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 23, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune shows power but wont function
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Neptune dryer runs then shutsoff then starts again
probably bad computer board expensive repair hope you love the machine
Mar 30, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Maytage neptune dryer wont start
heatman101
Feb 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The lights on the dryer work it wont start it didnt have any problems drying before this happened no odors or smells i have a maytag MDE5500AYW. please help. thank u
If the display on the dryer reads '88' then place a heating pad over the display. After a few minutes, the '88' code will clear, and it will work fine. Sounds crazy, but works every time for me.
Sep 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Feb 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Display
Check your manual. Sound like wrinkle guard setting
Nov 17, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Neptune Dryer
My maytag neptune dryer quit heating, after my wife changed the temp setting on the console from regular, to extra low drying temperature. The heating element reads 10.5 ohms. The thermal cutoff reads 0.02 ohms. The hi-limit thermo reads 0.02 ohms. The power coming into the dryer is 240 volts. What can I check or need to replace.
Dec 05, 2006 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
