Question about Sears Garden
Sears ride on mower acts like a dead battery but battery is charged
Stater clicks turns over slowly , sometimes it will catch and start
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Clean all the large wires to the battery and to the Starter solenoid
Posted on Jul 24, 2013
riceski
  • 1851 Answers
SOURCE: Briggs and Stratton 11 hp motor on Mtd ride-on
Sounds like you need to remove the starter and see what you can do to check it out.
Posted on May 05, 2010
  • 5 Answers
SOURCE: Toro ride on mower won't start
Try replacing your spark plug. If that fails then go to the engine, cheak your carb, lines, and gas. cheak for gum in the engine/carb. If gummed then get carb cleaner and spray twice, wait 1 hour then try again. If my solution fails then you might need expert help. Good Luck!
Posted on May 24, 2009
  • 59 Answers
SOURCE: mower won't start
sounds like the ground cable is bad
Posted on Jun 26, 2009
  • 8 Answers
SOURCE: cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
Posted on Aug 16, 2009
  • 203 Answers
SOURCE: Mower will not start, battery cgarged up but onlhy
Check all the wiring connections on the starting system. Start at the battery. Both posts. Then, check where the ground goes to the body of the tractor. Make sure it's not rusty and making a good connection. Check the wire from the battery to the solenoid. If worse comes to worse, you can take a jumper cable and go from the battery + side and jump right to the starter post where an electrical cable connects. This will let the engine turn over, but make sure you have the mower in neutral and brakes set, with blades OFF!
Posted on Jan 28, 2010
Dead battery in cub cadet riding lawn mower
sounds like the stater is not charging. check connections if that don't fix it test to see if stater is charging
Jun 14, 2016 | Cub Cadet 2012 - LTX1042 KW - 42 Inch Lawn...
Battery won't hold charge, but mower will start using a jump pack. After running it , when you cut it off it just clicks when you turn the key to crank it.
check all the connections for a loose or corroded joint. the stater could also be bad. check to see if it is charging when running with a meter.
May 26, 2016 | Swisher 44-Inch 12.5 HP Trailcutter...
Any ideas to why my VIP champion won't hold it's charge? It's dies out even while riding.
the stater is probably bad, not recharging the battery. if your mower is not charging and the battery goes completely dead it may die.
Apr 21, 2016 | Garden
It will start a few times but then if acts like the battery is dead but you can take the plug out and it will turn over
How old us the battery..Sounds like your battery may show full charge but is weak under load (starting engine) no plug no or little load.....have it load tested at a repair shop or you can buy one at any retail,store like Sears,Home Depot ,Loews or harbor freight..cheap and easy to use..good luck..
Aug 12, 2015 | Garden
I have a viking 830 ride on that is not charging can any one help. Have changed the stater
First thing I can suggest is checking the battery, if there is a dead cell it will not take a charge
Nov 28, 2014 | Garden
Riding mower won't start & makes clicking sound when I turn key over
MAKE SURE BATTERY IS CHARGED IF IS THEN JUMP LAWN MOWER AT STARTER IF STARTS BAD BATTERY ARE STARTER RELAY COST 60.00 I STILL THINK YOUR BATTERY IS BAD OR DEAD NOT ENOUGH CHARGE IN IT
Sep 01, 2014 | Garden
I have a riding yard machine mower. Had trouble starting without jumping the battery. Bought a new battery & it started right up. Mowed the front & side of the yard & shut it off to open my...
Now you are describing 2 different problems... If you have nothing I doubt the battery is dead but would check for a safety switch problem. If it clicks or turns over slowly then we need to be looking at a bad connection or other issues... Please describe your problem better to let us help you solve it
Nov 13, 2013 | Yard Machines 155 Torque Briggs Stratton...
Ride on mower with battery fully charged, fuel tank full, clean spark plug, when trying to start just get a click sound
It sounds like a soleniod ,battery or stuck or broken stater. Try jumping it with a charger or jumper cables after checking battery for corrosion and lose connections. Then progress to the solenoid ,then to the stater . After that it's more than likely a wiring issue.
Jun 12, 2011 | Garden
Sears riding mower
Even new batteries can be bad. All it take is one dead cell in it and it won't be enough to start the mower. The other thing to look at is the cranking amps of the battery. The cheapest wally world battery won't cut it for the larger motors. www.nnyparts.com
May 29, 2010 | Garden
Cub cadet 2140 wont start or turn over
Aug 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
43 people viewed this question
Top Sears Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
Dennis Key
Dennis Key
Are you a Sears Garden Expert? Answer questions, earn points and help others
