I have an pnkyp HTR-500 reciever that shuts of every time i try to turn it on part#2301381 is discolerd and melty looking inside what is this part and what is the problem
  • 3,799 Answers
The chances are that the part you are describing is a Capacitor and is part of the power circuit. It can be replaced and they are commonly described like this when failed. The capacitor failure will give the symptoms you describe.
Posted on Jul 22, 2013
Power
Audio amplifier IC damaged need to be replaced
Apr 23, 2010 | Yamaha HTR-5730 Receiver
HTR-5280 Receiver Fuse Blown
the fuse rating should be printed at the back near the fuse holder itself. If it opens the fuse again and again probably you have a circuit loading problem in the receiver...either one of the amps is failing.
Aug 10, 2009 | Yamaha HTR-5280 Receiver
Yamaha HTR-6130 Receiver will not stay on! Shuts
One last try with everything disconnected!
Other than that I suspect internal surge damage.
Aug 04, 2009 | Yamaha HTR-6130 Receiver
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
Problem with sp cable (yamaha)
The speaker cables are the ones that clamp or tighen down on the back of the reciever. All the spkr wires have to have the positive and negative leads correct. Also not aven one little strand of wire can be touching another conductor or you will have this problem. Make sure all leads are correctly ran and hooked up positive to positive and negative to negative from the back of the reciever all the way to the speakers. This should solv your problem.
Jul 25, 2009 | Yamaha HTR-6030 Receiver
Htr-5730 yamaha reciever
try another outlet sounds like you may have a short in either your power cord/supply or your outlet is acting up with the wiring
Feb 22, 2008 | Yamaha HTR-5730 Receiver
Yamaha HTR-5990 Audio no longer works
Sorry Michael, you have a problem in the audio amp section of the receiver and unless you know how to troubleshoot solid state electronics, you will need to have this unit serviced by a pro. Good Luck
Jun 21, 2007 | Yamaha HTR-5990 Receiver
Center Channel is failing itermittently
some of the theater selections sometimes effect this i think. check different fields also.
Jan 11, 2007 | Yamaha HTR-5280 Receiver
Should I just Buy a new one?
You have a bad power supply or the audio output circuit has a short in it. You are correct by saying its probably betterv off getting a new unit. Most likly cost you more then a brand new shiny unit would . Good Luck PS Please do not forget to rate this thread
Dec 10, 2006 | Yamaha HTR-5740 Receiver
16 people viewed this question
 Grubhead
Grubhead
