Question about GE Heating & Cooling
When i plug in the ge air conditioning unit. the reset button on the plug, will not restart the unit.. the test button shorts it out.
ACTECH
  • 80 Answers
SOURCE: air condition won't work
THE CLICKING SOUND IS A RELAY PULLING IN ITS LIKE A SWITCH CONNECTING TWO WIRES. THIS IS A GOOD SOUND BUT IS USALLY FOLLOWED BY SOMETHING COMING ON FAN ETC... CHECK TO SEE IF YOUR UNIT HAS AN LED LIGHT ON IT AND HOW MANY TIMES IF ANY DOES IT BLINK?
Posted on Jan 14, 2008
buffalonyman
  • 1865 Answers
SOURCE: Doesn't operate when plugged in
The test and reset is a GFCI device. They do go bad sometimes. The solution is to cut that plug end off, and install a regular cord end that is capable of handling the rated amperage of the unit. ( I assume this is 120-volt unit)
You should replace the wall receptacle with a GFCI receptacle where the unit is plugged in to prevent electrocution
Posted on May 02, 2009
mastatech
  • 478 Answers
SOURCE: I can't find the reset
If there is one it is rihgt next to where the copper lines enter the outdoor unit. There should also be a none reszetable fuse on the furnace control board
Posted on May 10, 2009
  • 88 Answers
SOURCE: wont turn onwhen i plug in.
the control might be bad or the power board...you will need to check this first.....
Posted on Apr 03, 2010
atocrxr
  • 135 Answers
SOURCE: Where's the reset button on a Goodman air
I believe that the higher end units have auto reset pressure switches, if you look down the inside of the unit, you will see one or two pressure switches welded to the lines,,,there are about the size of a "C" cell sized battery, with 2 wires running into them, if it is a manual reset type there will be a small rubber coated button on top, between the 2 wires.
If this has been helpful, please rate me, and/or contact me back with any further questions.
Sincerely,
Paul Gibson
Posted on May 03, 2010
I HAVE A FEDDERS AIR CONDITIONER MODEL AED24E7F-C THIS UNIT TRIPS THE RESET BUTTON ONCE IN A GREAT WHILE IT RUNS FOR HOURS OR DAYS ON END AND THEN TRIPS. IT TAKE AWHILE AFTER THAT BEFORE I CAN RESET...
The reset button is part of the cord. The cord has built in arc detection. This is a complex circuit that monitors the unit and senses potentially dangerous sparks or arcing inside the internal components of the A/C (motors, switches, etc.) It sounds like the problem is getting worse - as they usually do. Sparking and arcing happen when dirt, corrosion, etc. accumulates and can result in pitted contacts. All of these conditions only make the sparks and arcs worse. Page 1 of the manual (left column) says this:
If the Arc Detection Device has tripped, the
reset button will pop up.
Follow these steps to reset the Arc Detection
Device:
1. Unplug unit from electrical outlet
2. Press the reset button
3. Plug the unit back into electrical outlet
4. Check to see if power has returned to the unit
Testing
You should test the Arc Detection Device
equipped power cord monthly, after every major
electrical storm, or if power to your Room Air
Conditioner has been interrupted.
Follow these steps to test the Arc Detection
Device:
4. Press test button. Unit should trip and reset
button will pop up.
5. Press reset button again for use
If above test fails, stop using the air
conditioner and contact customer service by
calling the following toll-free number:
1-800-332-6658 or email:
customerservice@fedders.com
I hope this helps & good luck!
Aug 30, 2011 | Heating & Cooling
My one year old 8000 BTU GE window unit will not turn on. The electricity was going off and on so I unplugged the air conditioning unit off. Now it will not come back on. The green light on the plug is on...
Is the display panel lit up? If not look for a fuse mounted on the board.Take the fuse to radio shack and get another. Unplug the unit before attempting to service it.
Jul 09, 2011 | Heating & Cooling
Have Kenmore 85501 Air Cleaner. Unit will not restart after power failure. Send unit to Sears Service Center but they declined to fix unit. Tried to hold timer and function buttons for 5 seconds and...
Turn the Master ON/ OFF Switch to OFF and unplug the unit. Wait 12-15 minutes and plug the unit back in. Turn the Master ON/OFF Switch to ON and set your controls. The 12-15 minute timeout should have allowed the unit to reset itself.
Apr 16, 2011 | Kenmore EnviroSense 85501 Air Purifier
Air condition wont turn on
Do you have enough power to unit? Check plug for any loose wires on unit, with unit unplugged of course.
Jul 07, 2010 | Fedders A6Y18F7BCOM Air Conditioner
I got brand new GE air condition and accidentally I pushed test button located on plug (So green light on plug turned off). I tried to start my AC by pressing reset button. But somehow it?s not working....
That is a circuit protector...just like what you would see on a bathroom outlet. It is possible the switch is bad and when you pressed test...it stuck in the open position and will not reset. I would unplug unit and firmly press reset from a couple angles. You may end up getting a new switch for it. Sorry for your inconvenience.... If brand new maybe you can return it?
May 13, 2010 | GE AJCQ08ACB Air Conditioner
Cannot engage RESET Button on plug to power the 220v AC unit
The reset button is a voltage leak detector it is possible the unit has a short in it or the cord has a short
Apr 28, 2009 | Heating & Cooling
PTAC UNIT QUIT WORKING
If you have a clamp tester, operate the unit with the clamp tester and check the current reading. If the current reading is normal but the reset button is tipped then there is something wrong withe power plug reset button. But if the current reading is higher than the name plate rating then there is something wrong with the unit.
Mar 09, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Air condition problem
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The manual says to clean filter and unplug unit, then plug unit back in and code will be reset.
Aug 02, 2007 | Sharp AF-S120FX Air Conditioner
Air condition won't work
Jun 08, 2007 | GE AGM24DJ Electronic Room Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
