Question about Symphonic Televison & Video
Antenna hook up
I HAVE AN ANTENNA HOOKED UP TO THE SYMPHONIC TV BUT I AM GETTING NOT CHANNELS I WONDER WHAT WRONG ANTENNA FINE JUST NEE TV!!
If you are using an indoor Antenna:
1- the most probable reason would be the location of the antenna and TV in an area where the reception is very low. Indoors all houses are affected by the running electrical circuits which in turn generate magnetic field that together with the structure of the house obstruct or weaken the wave signals of wireless and TV reception. Also this issue may be aggravated by the vicinity you are live in. Where you are living may not have the optimum reception from some services including TV signals. Your best bet is to try moving the (Indoor) antenna closer to the outside (such as windows, or better to a balcony) and try all four directions of the house.
2- One other possibility, is the antenna jack being disconnected from one of its wires (or a de-solder) at an internal part of its circuit). This problem can be detected by trying another antenna that is working good when used with another TV (and preferably at a different location) thus testing for the possible weak signal at the same time.
3- The last possible issue is the antenna receptacle built onto the Tv set. This may have a problem of some element of it disconnected internally on the board or de-soldered..
If the Antenna is external, all the above points are still valid, but the probability is higher, for some hidden disconnection on the receptacle, the antenna plug or at the connection of the co-axial cable with the external antenna. (Once I found a co-axial cable with disconnections of its central copper wire within the protective insulating coat- probably due to defects in the plastic coat that had microscopic holes that allowed air and humidity into the central wire and caused it to corrode and have those discontinuities)..
Posted on Jul 22, 2013
  • 125 Answers
SOURCE: Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
Posted on May 24, 2007
  • 93 Answers
SOURCE: cannot program cable to tv
if your are using a cable box,all of your channels will be control only on the cable box.so, what you are going to do is use the remote control of the cable box.
Posted on Nov 07, 2007
SOURCE: 19" ge tv/vcr combo receives vhf channels but not uhf
when i turn on , few seconds later goes off ..help
Posted on Dec 16, 2008
SOURCE: can't get any channels on Coby tv
Yes, you need an antenna -- rabbit ears or some other type of digital antenna.
Posted on Mar 29, 2009
tvtek
  • 1284 Answers
SOURCE: Lost the remote
Without the Panasonic remote you can not get to those features to program these sets. I have included a link to purchase a replacement remote control. They aren't expensive and much easier to use than a universal remote. Please take a moment to rate my answer. Thanks...
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=pvdf2004&uuid=12592148630250
Posted on Nov 26, 2009
Do I need an hd convert box to get free channels
If you have a digital tv then no. Go to menu, click on input, click tuner or tv, click antenna, run auto scan for channels. Make sure antenna is hooked up. Digital antenna is preferred but not mandatory. If you're not getting channels move antenna re-scan for channels. Hope this helps!
Jan 29, 2016 | Televison & Video
Hooked up to antenna did channel scan in air mode not getting any channels. Hooked up a Vizio tv to same antenna line and got all the locals. Maybe something wrong with the Sharp?
Make sure that Sharpe is set to over the air/antenna and not cable. There are more than one scan modes. http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/tel_man_LC42_46_52D65U.pdf
See page 14 in the link. It is easy to mis-configure the setup to not receive the over the air digital channels. The input must be set to digital and air in setup. The VHF are no longer available.
Hope this helps?
Jan 15, 2016 | Sharp LC-32DA5U 32 in. HDTV-Ready LCD...
I just hooked an antenna to my sony bravia and it only picks up a few digital channels. I have two other Tvs hooked to the same antenna and the both pick up so many more channels. What could be the pr
i think the 'front end fet' or channel fet has failed
this amplifies the incomming antenna signal
however is the center pin of the antenna plug on the tv loose
inside the tv is a metal box this is attached too
it changed the UHF signals to a lower frequency range called an IF
the UHF signals are normaly have a path like this
antenna>>safety >>>amp>>mixeramp>>output to DTV decoder etc
the amp bit or connection to the tv is wrong
as its working quite well and gets like 2 channels
look inside the socket on the tv and examine it carefully for any bits of wire
or as i say loose connections
may just need to be soldered inside the can to reconnect the center pin
it will still give like 2 3 channels as the gap caused by the bad solder joint
will still allow some RF accross
so... its either a gubbed UHF RF amp or a broken connection or a short ... so...
Dec 11, 2014 | Sony Televison & Video
32in Vizio getting no channels
You have to go to your menu screen and change the settings from antenna to cable that should take care of it, and should be able to do a auto scan to load channel memory
Mar 26, 2013 | Vizio VX37L Television
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
I have an LG47LG70 tv which has recently started flashing the screen on and off when hooked up to the local antenna. It works fine when hooked up to the Dish Network cable. I have replaced the antenna...
Tries hook up to a roof antenna or a better antenna like a digital antenna.Than rescan ur tv again,for those DTV free air channels again.Ur tv now,should get all those DTV free air channels.
Nov 05, 2010 | LG 47LG70 42 in. LCD TV
HDTV unable to get HD Channels w/ Antenna
The problem could be your antenna. Many people will buy small indoor tv antennas and wonder why they're not getting the signal that they want or the channels that they expect. Its not your fault. Digital signal is in two formats: UHF AND VHF. Some antennas only receive UHF. But many of the low band channels are VHF, so 1) you need an antenna that will receive those signals and 2) you need to know how and where to install that antenna and 3) you need to know if you need a signal amplifier depending on your coaxial cable length and number of connections. I recommend visiting dennys antenna service (no I don't work there and I have never purchased anything from that website. He just has an excellent informational article with a great deal of "how to" on his pages.). http://www.dennysantennaservice.com/2029710.html This should be of great help to you. Happy viewing =)
Dec 26, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
Programming
can you enter channel 4 manually and get picture
Nov 19, 2007 | Zenith Z19A11S TV
Televison & Video Logo
75 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
